Old 05-02-2005, 02:21 PM
kingpinn's Avatar
kingpinn kingpinn is offline
just want to know what you think or would do
if you had a 88-91 si with 200k miles and some one gave you 2500 dollars to make the car a quick car but still a every day driver what would you do ? what mods ?
Old 05-02-2005, 02:30 PM
FuLL BLown STD's Avatar
FuLL BLown STD FuLL BLown STD is offline
Send a message via AIM to FuLL BLown STD
Id do a engine swap right uh way of course, JDM DOHC vtec.. dont know if id choose SiR or GSR, I/H/E $2500 can get you alot if your a smart shopper and if you know the right ppl, just gotta wait and have patience buddy, dont waste ur cash on those online motor malls!!!
Onimacus's Avatar
Onimacus Onimacus is offline
Send a message via AIM to Onimacus
Re: just want to know what you think or would do
DOHC ZC I/H/E suspension.
Travis
Old 05-02-2005, 03:29 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Suspension, Intake, Exhaust, and a nice tune-up or maybe a swap or you could rebuild that d16a6 with...
a better cam
89 integra pistons (or equivalent higher compression domed top)
metal headgasket
ARP head studs
Unorthodox Racing pulleys
Exedy Stage 1 (or 2) clutch
ACT 11.9lb. Flywheel
AEM intake
DC header
DC or Thermal R&D catback
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-02-2005, 04:04 PM
kingpinn's Avatar
91 Civic 1.5 HB .. where can you find a b18c swap for 2500
Old 05-02-2005, 05:24 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
if you know how to swap the motor yourself, all youll need to spend in like $2000, then you can put cams in or something with the extra 500.
i wish someone would give me 2500 to spend on my car
Team Lonely Drivers
Old 05-02-2005, 06:12 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
I personally would do a B16A1, which should cost about $2200 (max, this is like $400 extra 'just in case') if u do it yourself... U should have more than $300 left over if all goes well, then do a nice drop (I personally think a swap and a drop would be best all around fun, then add an I/H/E later on since they are generally cheap mods)...
BTW, theres no prob with online motor malls... IF u go with a reputable one! For some people theres no other choice, me for instance, theres nothing in my area that would have JDM swaps...
Old 05-02-2005, 06:53 PM
plsANSWERme plsANSWERme is offline
Re: Re: just want to know what you think or would do
2200 for a b16? BS atleast 3000 unless u wanna cheap out and hope ur timing belt and or water pump doesnt sh*t out onu remember hondas are interference engines .........
Old 05-02-2005, 07:51 PM
Re: Re: Re: just want to know what you think or would do
I dont know where you've been looking, but when I was pricing my B16 swap... I came up with $2200, which includes timing belt, pump, mounts, ect, all included in the 'just in case' money... The swap itself is only 1299.00 + shipping (about $310) from a reputable shop...
http://www.totaljdm.com/index.cfm/fu...dm_engines.htm
So thats $1609...
Plus Mounts = $200 (if u look u can find a set of HASport of this price)
So we got $1809...
Shift linkage (I was just gonna modify the existing one, or hope it was from a Civic and would work) = free
And if u cant get a timing belt, tensioner, water pump, and other various things for less than $391 u have problems, I know for a fact U can get all 3 for $150-$160 from hondaautomotiveparts.com... So that leaves u $231 for hoses, the axles ($140), and extra stuff that needs to be replaced... It can be done for $2200...
Lets even add on an extra $300, well say $2500 total for the swap TOPS... If u do it yourself, theres no way it would cost more than that... And if it does, then u should return your engine, cuz your replacing stuff that should be covered under your warranty...
Ive honestly never heard $3000 for a total price of a B16A1 swap...
