| Non-Performance This is the place for all interior, exterior, and general non-performance modifcations. |
Blinkers
ok so when i go to put my blinkers on they go on but they dont blink the light both inside and out stays solid, anyone know what the problem is?
Re: Blinkers
check the flasher solenoid deal thats in your fuse box under your dash, driver side. I beleive its the big round canister, about the size of a half dollar. That went out in my f-150 (90) and it would do that. Its like $3-4 at autozone IF thats the problem. Let me know if that works.
Re: Blinkers
thanks alot ill check it out and see if thats the problem
Re: Blinkers
damn, i changed the flasher and that wasnt the problem, my hazards work, they flash jus my blinkers dont, im guessing its the switch
1990 Mustang LX - No Blinkers Either
I've got the same problem. I checked all the fuses and replaced the flasher solenoid, but still no turn sgnals. The four way hazzard lights work fine. Any ideas as to where I can get a new or used switch? The local junkyards don't have any. Also, have you heard of anythind else that could cause this?
Thanks much. |
Re: Blinkers
Check your bulbs. Typically if one of your bulbs is bad, it will cause a chain reaction resulting in what you describe.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
I discovered that my ignition switch had failed; I replaced it and the problems vanished. A new ignition cost $12.00 at NAPA.
Good Luck! |
Re: Blinkers
ok found the problem, it was the other flasher in back of the radio.
