Old 05-02-2005, 08:25 AM
MSimpson MSimpson is offline
Dumb Question..
This may be a dumb question but do the 1995 GMC Jimmy have a gaslight? When the fuel gets low in my truck I never see one. So I am not sure if mine is bad or it just doesn't have one..
Old 05-02-2005, 05:32 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: Dumb Question..
No, pay attention to the fuel level.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-02-2005, 07:14 PM
coryhawkins coryhawkins is offline
Re: Dumb Question..
If you know about what fuel economy you get (MPG), you can use the trip meter to help you tell when you're about to run out too. I have to do that with my 98 because the fuel gauge sits at full for 100 miles, then drops quickly to 1/4 and stays until I'm almost out of gas. I know when I get up near 300 miles on the tripmeter, I've used 13-15 gallons and it's filling time. The light comes on when I've got about 2 gallons or less left, and I don't like to get it that low in case I'm not near a gas station that I want to stop at (I only use top tier gas).
Old 05-03-2005, 12:15 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Dumb Question..
Also note, is is not a good idea to constantly run your tank to empty before filling it.
1/4 should be the lowest you allow it to plunge to unless in a situation where you cannot find a station.
The gas also acts as a cooling agent for the pump.
Also, condensation in the tank becomes a major factor when leaving the tank empty.
Old 05-03-2005, 06:59 PM
chcknugget's Avatar
chcknugget chcknugget is offline
Send a message via AIM to chcknugget
Re: Re: Re: Dumb Question..
Condensation from what? -Water in the gas? Just curious
Old 05-04-2005, 12:14 AM
BlazerLT's Avatar
AF -Advisor
Re: Re: Re: Re: Dumb Question..
When the tank empties, it draws in air from the outside.
This outside air has moisture.
Old 05-04-2005, 08:24 AM
BlazerBoyLT98's Avatar
BlazerBoyLT98 BlazerBoyLT98 is offline
Send a message via AIM to BlazerBoyLT98 Send a message via Yahoo to BlazerBoyLT98
Re: Re: Re: Re: Re: Dumb Question..
Very informative. I have never really worried about it in my truck but I have always worried about it in my sled. I am constantly pouring in isopropyl fuel additive to keep it from freezing up on a really cold night.
2002 Pontiac Gram Am
K&N Air Filter
Mobil1 5W-30 Extended 15K
2 JL Audio 12" Subs Sealed JL Audio Box
Coustic 400 Watt Class D Mono Amp
Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner
Polk DB750 6.5" all around
Yankees Suck!!!!!!!!
Old 05-04-2005, 04:14 PM
BlazerLT's Avatar
AF -Advisor
Re: Dumb Question..
Easy way to stop it is to keep the tank above half at all times.
Plus your fuel pump will last longer.
Old 05-04-2005, 04:33 PM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: Dumb Question..
added note, the pump uses gas as coolent as stated, if it gets warm, around all the cool stuff inside, thats how the moisture condences, like a cold drink on a hot summer day
