Starting Problems...
My moms 97 Quest wont start... unles syou leave it in batt mode for like 2 minutes.
If you try to do it immidiately.. it has the same effect as when you try to start a car without a battery. The negative terminal cabling is white and blue with some frosty looking stuff which i can assume is rust or oxidation.... any comments on what I should do or what else could possibly be the prob? Dont know why it gets the juice to start if i let it stay in the ON mode for 2 mins... help me out!!! Thanks in Advance!
Are stock tips worth anything? See how the experts do: http://www.stocktiptrader.com |
Sounds like you have some battery acid crud on the connections. Sometimes they can get so bad that it will act like there's no battery because there isn't, it's basically not connected. I'd run a battery terminal cleaner over the posts and on the cable ends, put a little dielectiric grease on the posts, and put the little felt washers on before I bolted the cables back on. Every Quest we've had has had problems with crud building up on the battery cables, and a good cleaning & greasing will fix it, but the felt washers almost stop the buildup.
HTH
1996 Villager (newest, 80k miles, CLEAN!!) 1995 Villager 147k (new driver, bad lifters, 24.5mpg) 1993 Mercury Villager 156k (fair game for parts) 1993 Mercury Pillager 178k (Pillaged 4 parts) 1995 Nissan Quest 194k (driver) 1995 Mercury Villager (sold 181k) 1996 Mercury Villager (sold 134k) 1995 Mercury Villager (sold @ 184k) 1993 Nissan Quest (sold @ 137k) 1998 Mercury Villager (sold @ 90k) |
