Go Back   Automotive Forums Car Chat > Toyota > Avalon/Pronard
Old 05-02-2005, 12:13 AM
DArealPERCH DArealPERCH is offline
Replace cabin filter 1997 avalon
Anyone know how to replace a cabin filter for a 1997 avalon. I read it needs to be replaced every 15,000 miles or if there is a stale smell in the car. Any help would be appreciated.
Old 05-02-2005, 06:45 AM
tfeld tfeld is offline
Just did it on my 2001--don't know if they're identical, but should be very similar I think.
All you have to do is remove the 5 screws that hold the glove box in place, then pull it out. Be careful--there is a wire connected to it at the top left--so don't pull too far or hard.
Once you can lower the glove box, you'll see the filter door at the top of the blower assembly. Just pop the door off and replace the filter. Note that the filters are directional, so when you install the new filter, make sure it's oriented the same way as the old. There are directional arrows on the side of the filter.
Old 05-02-2005, 07:59 PM
Re: Replace cabin filter 1997 avalon
Thank you will go and see if this works
Old 06-14-2005, 11:19 PM
ToyotaTech1 ToyotaTech1 is offline
Send a message via AIM to ToyotaTech1
Your car is not equipted with a cabin air filter I believe in avalons they started putting them in starting with 2000
Old 03-12-2010, 08:44 AM
guillo05 guillo05 is offline
The 1997 Avalon does not have a cabin filter. I removed the glove compartment and it only has the fan. However, the 2004 Toyota Sienna does have a cabin filter, and the replacement process is very easy. Remove the glove compartment as previously mentioned. It is very, very easy. You will win points with the wife and kids.....
