Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 05-01-2005, 09:30 PM
SoapDish SoapDish is offline
Tail lights out, I think it is a blown fuse
I have a 91 and both tail lights went out the other day. the brake lights, hazards, and blinkers all work so I am thinking that I blew a fuse. The problem is that I never recieved an owners manual when I bought it so I have no idea which fuse(s) to check. Does anyone know where I could find a fuse diagram?
Old 05-02-2005, 02:23 PM
biv343 biv343 is offline
I think that the rear tail lights are on the same circuit as the front parking lights. Turn on your headlights and see if the front parking lights come on. If they do, I'd check the bulbs. I've had both of mine blow within a day of each other in the past on some of my previous vehicles.
The fuse might be called PARK LMP or TAIL LMP or something like that. It should be labelled fairly well.
Old 05-02-2005, 02:24 PM
One other thing - reason I suggested checking the bulbs is that the taillight bulbs are dual filament - one filament is used for brakes, blinkers and hazards, and the other filament is for the tail lamps/running lamps.
Old 05-04-2005, 07:17 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Tail lights out, I think it is a blown fuse
The little solder balls at the end of the bulb also wear out flat and quits making connection.
