Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '71-'87 Civic | CRX
Old 05-01-2005, 07:58 PM
basek basek is offline
removing the OHC Wheel
anyone got a tip for removing the OHC wheel so I can replace the seal?
is it reverse threaded?
cheers
Old 05-02-2005, 02:13 AM
lxndr's Avatar
lxndr lxndr is offline
AF -Advisor
Re: removing the OHC Wheel
Are you referring to the cam gear?
If so, loosen the cam gear bolt (standard right hand thread), slide the timing belt off, then remove the cam gear bolt all the way. The gear should just slide right off the end of the cam. Before you do any of this, make sure you line up the TDC mark on the crank pulley, or line up the timing marks on the cam gear. This will make reassembly much easier!
Old 05-03-2005, 04:23 AM
thanks sorted...
