Rough Idle
I have a 1998 Chevy Blazer with a 4.3 vortex 6 cyl. My problem is I am getting a very rough idle or stumble. I replaced plugs and wires and the problem still exist. I even went through the trouble of pulling the new plugs and check to see if I cracked one putting them in. I also cleaned the throttle body and connected my snap on MT2500 scanner. After going through the diagnostics there are no codes present. I even tapped on the MAF sensor and it does not affect the stumble at all.Any one ever have this happen to them???
Re: Rough Idle
Did you change the cap and rotor?
Re: Rough Idle
If you didn't replace the cap and rotor, that is probably your problem.
You can also try cleaning the EGR valve and running some Techron through the tank. |
Re: Rough Idle
Replace the PCV valve also, it will cause a rough idle.
Fuel and air filter too.
1995 Factory Blazer Service Manual for sale, PM if interested. |
At the risk of sounding like a total IDIOT I have to ask..... I thought this particular vehicle was distributorless?
Re: Rough Idle
Nope, it's got one. If you replaced the wires yourself, you plugged them right in the cap. That needs to be replaced as well as the rotor inside of it. You can get an AC Delco cap and rotor from rockauto.com for a decent price. (that's where I got the ones for my 98 Blazer.)
I see were the plugs wire go but I thought it was the coil assembly in a DIS system..... I am an IDIOT!!!!!!!!!!! LOL
Re: Rough Idle
The DIS is on the 2.2L S10s Yours has EDI. (Enhanced Distributor Ignition) |
Thanks.........Boy was I misled!!!!
Re: Rough Idle
You're welcome.
The screws have Torq heads. You will need a T-20 for the cap and a T-15 for the rotor. |
Re: Re: Rough Idle
They are only plastic. Tighten till firm and snug ONLY.
I still have the rough idle after replacing the cap and rotor rechecked to make sure i did not screw anything up and it all looks good any have any ideas??
Re: Rough Idle
A rough idle has several common causes:
Some other routine maintenance items that can help are: Air Filter Fuel Filter and PCV valve Another common cause of a rough idle is carbon build up in the EGR valve: Simply remove the valve, clean it, and reinstall with a new gasket. In your other post you said you cleaned the throttle body. This may be another surprise to you...the throttle body only lets air in. You have an injector system located inside the intake manifold. It has six injectors one for each cylinder. The fuel enters the cylinder through a poppit valve. These valves are known to clog and cause a rough idle. The most effective way I know to clean them is to add a bottle of Techron to your fuel tank. Last edited by blazee; 05-06-2005 at 08:19 AM. |
Re: Rough Idle
Re: Rough Idle
[quote=freddie cosme]I still have the rough idle after replacing the cap and rotor rechecked to make sure i did not screw anything up and it all looks good any have any ideas??[
What do you recomend to clean the EGR?? Brakeclean?? |
