Old 05-01-2005, 05:49 PM
evansdad evansdad is offline
Send a message via Yahoo to evansdad
94 grand am acclerates by itself?
When I stop at a light or a stop sign the car wants to take off by itself. what is this? could it be the throttle position sensor. oh yeah the motor is a 3.1L
Old 05-01-2005, 06:38 PM
catback23 catback23 is offline
Re: 94 grand am acclerates by itself?
It's haunted. Want's to take off as in? The brake lets up or do you mean the engine revs higher? The computer will rev the engine higher if it thinks the engine is going to stall. I doubt the TPS is at fault but it's probable.
Old 05-01-2005, 07:36 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
It could be the TPS, or more likely, the MAF. A messed up MAF will sometimes increase RPM's dramatically. If you have a working MAF, and want to experience this, unplug your MAF and drive around a little bit. It's actually hard to control the vehicle sometimes.
Old 05-01-2005, 11:12 PM
Knifeblade Knifeblade is offline
Being a '94, one other possible is sticking linkage/cable at the throttle body. Spray down the linkages and the cable ends to ensure free movement. Check from inside the ride that your gas pedal moves freely and doesn't bind.
