Old 05-01-2005, 03:21 PM
smokejaguar smokejaguar is offline
Question carter afb
I got a 86 Silverado 305 LG4 with a carter afb 4 barrel. Its a good carb, fairly new. i failed emissions 2 weeks ago, so i brought it to get fixed at a chevy dealership. They were suppose to adjust carb to make it pass. It didnt pass, and they screwed up the carb real good. It was idlein wicked high, and i could hardly stop at stoplights. I turned down the idle and noticed the carb was makin nose. It made a hissin sound for some reason. I got 2 air screws in the front of the carb, and i turned one. the hissin stoped. Wtf was the hissin. I think i was runnin too lean? Which way should i turn the 2 screws in front? Counter clockwise or clockwise? I dont want to run it too lean so i burn the valves out. I have no idea waht im doing, i just need information on that carb. Its the same as a edlebrock Performer seris too i think. anyone no how to tune that? -thanks
http://www.cardomain.com/id/smokejaguar
Old 05-03-2005, 12:27 AM
roadrunner_70 roadrunner_70 is offline
Send a message via Yahoo to roadrunner_70
Years ago, I had a Carter AVS 4 bbl on my '69 roadrunner. This carb had 3 idle mixture screws! The principle is still the same. It's not a good idea to mess with them unless you have some idea of what you're doing. But a rule of thumb is hook up a vacuum gauge to the intake(a tee connection) and, starting with the screws turned very lightly seated in(clockwise), turn them out equal amounts in 1/8 of a turn increments until you get the highest vacuum reading. Alternately, you can turn them in with the engine running until you first detect the engine rpm's dropping then turn them out til you hear the engine slow down or miss slightly. The ideal position is in between the two settings. Make sure you don't have any vacuum leaks elsewhere at the carb base or intake. The choke has to be fully off or open also. The air bleeds can be sprayed with carb cleaner. Sometimes this will smooth out a rough idle. If the idle becomes too high while adjusting the mixture, turn the idle speed screw down, and start over.
