Old 04-30-2005, 11:13 PM
phantomz28's Avatar
phantomz28 phantomz28 is offline
Send a message via AIM to phantomz28
Question Electric Supercharger
Well ive been hearing all this hype about electric superchargers. I know that they will not give you a significant boost in HP butthe would give somethign right? standars airintake for a 5.7 lieter is around 500 cfm. if i install an E.S. that blows 1000-1200 (25,000 to 28,000 rpm) at WOT that should give me roughly 1-2 psi of boost right? (all before the MFA so that air/fuel raio would remain the same.) i am just curious about what you guys have to say.
Old 05-01-2005, 12:19 AM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: Electric Supercharger
No.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 05-01-2005, 02:59 AM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
Crap!
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 05-01-2005, 10:50 AM
phantomz28's Avatar
yes yes yes i know their crap i'm just wondering about the physics. i'm not buying one gad no! if i get a supercharger it will be a REAL one!
Old 05-01-2005, 12:30 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
I thought about it myself a long while ago. and I highly doubt that any electric supercharger is built to hold any significant level of boost... they just wouldn't have enough power to force the air into the engine nor enough sealing power to keep the air pressure from escaping in the reverse direction. for example, let's say that your girlfriend can blow 1000cfm of air out of her mouth (hypothetically) when she whistles. That's fine. But when she puts her hand over her mouth, which would simulate the resistance to air flow that forcing the air into the engine would create, it's a hell of a lot harder to push that air... and even harder to create positive boost pressure. There is no eletric fan in existence that you can fit in an engine bay that is powerful enough to run off a 12volt battery and produce several pounds of boost.... these things are nothing more than electric fans and they do nothing that the engine wouldn't do by itself.
However your girlfriend would be pretty impressive... I would keep her away from me.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 05-01-2005, 12:54 PM
phantomz28's Avatar
LOL! yeah and thanks for not repsonding with "your joking right?" got alot of that and i just want to further educate myself on these things. have you guys heard of the R-ram? http://www.electricsupercharger.com
this is where i got my questions forming
Old 05-01-2005, 01:17 PM
those dyno results are full of shit. the don't eplicitly tell you that the higher numbers are a result of adding their "charger" (because it's not). a couple of the dyno runs show that they added a catback exhaust and some other stuff. it's all bullsh*t. there are a lot of better things you can do with $500 other than get ripped off.
Old 05-01-2005, 01:44 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Re: Re: Electric Supercharger
Awsome example
White 07 STI, Bone stock for now
Old 05-01-2005, 02:47 PM
phantomz28's Avatar
yeah 500$ is too much just for a 5% increase i thnk. but like i said before i just wanted to find out more information abotu the E.S.'s
Old 05-01-2005, 05:29 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
Here is how a turbocharger works.
Here is how their "supercharger" works
they don't do a damn thing.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 05-01-2005, 06:20 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
i would believe that this has to be ur shortest response to an electric super/turbocharger question yet...
u usually go into this long thing explaining everything and how they don't create boost, and by the end of the post u are really pissed off lol
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 05-01-2005, 06:43 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Even the preacher gets tired of speakin to the choir once in a while.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 05-01-2005, 07:28 PM
Hypsi87's Avatar
OK like I posted in the other eletric turbocharger thread.
ok peeps
A turbocharger DOES NOT INCREASE AIR FLOW BY BLOWING MORE AIR INTO YOUR SYSTEM. A turbocharger compresses the air charge and then feeds it to you engine. It's like taking all the air that is in the room your in right now and putting it into a beer bottle. Still the same ammount of air..... Just more compressed, Which means you have a more dense air charge.
Like this.
Now a "eletric supercharger just twirls around and does nothing.
In fact I garuntee that when you went WOT your engine would pump enough air to Drive the fan.
I feel visual learning is the most effectiveway to communicate
I am here to serve
Hell even this is the condensed version
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
Old 05-01-2005, 11:00 PM
Re: Re: Re: Electric Supercharger
lol yea it is...
Old 05-02-2005, 09:58 AM
LT1MAN LT1MAN is offline
Banned
electric supergarbage
