Old 04-30-2005, 10:36 PM
clawhammer's Avatar
clawhammer clawhammer is offline
Idle problems
My sister bought a 94 Talon turbo, fwd. It's in mint condition, other than a small problem with the idle. It seems to sort of bounce, and it even stalls sometimes. I'm just thinking that the idle screw needs to be adjusted. Can someone tell me where it's located (with pics if possible), and whatever else it could be if that's not it. The 1000 FAQ site is down at the moment. Also, can I find the repair manual for it online somewhere?
Old 04-30-2005, 10:58 PM
ned032002's Avatar
ned032002 ned032002 is offline
Well if you want to buy a repair manual then go to this site and choose which ever one you prefer
http://www.car-stuff.com/performance...e=repair_manua
I don't think that the idle surge problem that you have will be fixed by only that screw. I have an idle surge as well but I get rid of it by unplugging that green wire with the connector that sits on top of the throttle body next to where the intake pipe goes in. When I unplug that my idle surge goes away and there is no after effect but that doesn't fix it but... Good luck.
Old 05-01-2005, 10:29 AM
clawhammer's Avatar
Re: Idle problems
By repair manual I meant a scanned version available for download. I myself own both a Honda and a Toyota, and someone actually went through the trouble of scanning in the reapair manual for them. Like here's the link to the manual for my MR2: http://www.mr2-tech.com/bgb/mechanic...mechanical.htm
I was wondering if there is something like that for the Eagle Talon/Mitsubishi Eclipse.
As for the idle surge, what other things can I try?
Old 05-01-2005, 11:17 AM
Ogami Ogami is offline
Clawhammer,
I had that same problem last year that my idle would bounce and sometimes stall at a light if I didnt rev the engine alot higher then usual. For me the fix was to replace the Manifold differential pressure sensor, which is right on top of the intake manifold. But my car was throwing a check engine light with it, not sure if this might be your problem but just sounded exactly like my problem.
1995 Eagle Talon Tsi Turbo AWD 5 speed
Old 05-01-2005, 02:31 PM
91 Eclipse 91 Eclipse is offline
Send a message via MSN to 91 Eclipse
Re: Idle problems
ogami I have the same problem where did you find that part or should I just go to a junk yard. sorry for thread stealing my bad.
91 Eclipse GS 5-Speed 2.0L DOHC 16 Valve (Black)
Stock
93 Eclipse GS-T 5-Speed 2.0L DOHC 16 Valve (Red)
Cosmo Racing Air Filter
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
Megan Racing 3" turbo back exhaust
450cc Injectors
I am selling my 1993 GS-T eclipse for 3000 obo. it has a new engine with 15,000 on it, brand new 3" turbo back exhaust, Brembo rotors, and NEW Faze A/F gauge and Boost/Vac Gauge. will post pics as soon as I can PM if interested
Old 05-01-2005, 06:21 PM
clawhammer's Avatar
Re: Idle problems
Is that circled in red the ISC? Is that phillips screw the only thing that attaches it to the throttle body?
How do I disconnect the idle switch? Is that the red plug that's in the picture?
Old 05-01-2005, 06:32 PM
ned032002's Avatar
Re: Re: Idle problems
Isn't that the TPS? Thats what I thought it was.
Old 05-01-2005, 06:35 PM
ned032002's Avatar
Re: Idle problems
Where do I find this part on the engine, picture would be nice. Also does the 1st gen have this same part.
Old 05-01-2005, 06:40 PM
clawhammer's Avatar
Re: Idle problems
You mean unplug the green wire that the arrow is pointing to in the picture?
Old 05-01-2005, 06:46 PM
ned032002's Avatar
No, there is a green wire on the 1st gen, I don't know about the rest of the DSMs, but there is a plug like thingy on top of where the throttle cable connects to the throttle body. I would show a picture but I can't get it to work.
Old 05-01-2005, 07:10 PM
clawhammer's Avatar
Re: Idle problems
Let me run out to the garage and take another picture. It's a 1g
Old 05-01-2005, 07:17 PM
clawhammer's Avatar
Re: Idle problems
That one?
Old 05-01-2005, 07:41 PM
Mine was right on top of manifold can't miss it, on the 1st gen's not sure where it is. I actually got the part from a chrysler dealer, I have a picture on my home machine, I visiting my parents right so I'll post a pic as soon as I get home, so it will give you guys a hand in finding the part. I'll post the pics by tomorrow night for you guys.
Old 05-01-2005, 10:10 PM
ned032002's Avatar
Yes try that wire that is the one that I unplug and the idle surge goes away. I don't know what it goes to I never traced the wire so... good luck.
Old 05-01-2005, 10:59 PM
Re: Idle problems
yeah I have the same problem that when I take that off the surge goes away but idles high at like 2500 RPMS. the ISC is below the Black sensor or the TPS sensor to the left of the intake manifold or passenger side it has a plug on it, you can test this there is many threads about this.
Stock
Brembo Rotors
14b turbo
Faze Boost Gauge
Faze Air/Fuel Gauge
Dual Gauge Pod
450cc Injectors
