Go Back   Automotive Forums Car Chat > Honda > Integra
Old 04-30-2005, 10:35 PM
V T E C H's Avatar
V T E C H V T E C H is offline
No spark!!!
Ok, after rebuilding my engine for like... ever, i finally have it all back together. Timing is correct, everything is lined up perfect, new plugs new everything. I have no spark. I have no idea why. Battery is fine, fuses are fine. I am so confused, does anyone have any ideas what could be going on?!?!?!?!?
Thanks in advanced
95 Integra GSR, I/h/e, 15" TSW wheels, short shift, front & rear swaybar, lowered 2", 93 GSR head & intake manifold
Old 05-01-2005, 05:49 PM
eclipser2001 eclipser2001 is offline
Re: No spark!!!
is the engine turning over, jw. i would check the starter and the distributer.
Old 05-02-2005, 12:12 AM
V T E C H's Avatar
Re: No spark!!!
Ok, i got a new coil, and distributer rotar and that solved the spark issue. Now, we cant get it to start. I think i might have flooded the cyldrs trying to start it, is that a possiblity? i have no idea why it wont start, but at least i have spark, lol. Any advice would be amazing!!!!!
Old 05-02-2005, 08:36 AM
Re: No spark!!!
i would check all connections. might take some time though. gl to you.
i had a similar problem to your first post. i thought it was an alterator problem. i had no spark at all. come to find out i had a battery terminal disconected.
Old 05-02-2005, 02:40 PM
V T E C H's Avatar
Re: No spark!!!
Ok i think the distributer might be off by 180. i am going to adjust that and see what happens! YES GO ME! haha
Old 05-03-2005, 08:47 AM
Re: No spark!!!
i hope that helps. gl to you.
Old 05-03-2005, 10:48 AM
IntegraB16 IntegraB16 is offline
Re: No spark!!!
Did you check the plug wires to make sure they are put on in the correct order?
Old 05-03-2005, 01:41 PM
V T E C H's Avatar
Re: No spark!!!
I think they are in the correct order. the fireing order is 1-3-4-2 right? or am i off?
Old 05-03-2005, 02:36 PM
Re: No spark!!!
i thought it was 1-3-4-2, i may be wrong though.
Old 05-03-2005, 02:48 PM
Re: No spark!!!
That seems right.... But just do what i did... (If you want) just start sticking them in different orders until it fires up, or atleast runs funny, that way you know if it will run at all.
Old 05-03-2005, 10:04 PM
V T E C H's Avatar
Re: No spark!!!
hhahahahaha i guess i could try that....
Old 05-04-2005, 11:21 AM
Re: No spark!!!
i'm sure you already know... but don't try to switch the plugs while having someone turn it over. You will get an unpleasant suprise.
Old 05-04-2005, 02:22 PM
V T E C H's Avatar
Re: No spark!!!
^^^ AHHAHA yeah, i probably shouldn't try that
Old 05-04-2005, 03:06 PM
Re: No spark!!!
why not, what would happen?jk
Old 05-09-2005, 02:31 AM
V T E C H's Avatar
Re: No spark!!!
My car won't idel now... any ideas? i have adjusted the throttle so that it will idel for a little bit at like 700 RPM. But i will try driving around and soon as i hit in on the clutch to like coast or anything like that, it will randomly die. The car is running rough as hell as well.
