Go Back   Automotive Forums Car Chat > Chevrolet > Cavalier > Non-Performance
Non-Performance This is the place to discuss interior, exterior, and other non-performance related modifications.
Old 04-30-2005, 09:54 PM
jrey1717 jrey1717 is offline
Question subwoofer feedback pls need help
i have a 04 cavy and i hooked up an amp and subs to the factory deck, and ran the remote wire from the fuse box, the ground is in the top of the trunk near the lid and the line output converter is hooked up from one speaker to get the mono sound, and it is also grounded to the same place as the amp, but when i shut off my car the subs just pound at the same intensity without the deck evenbeing on, if i open the door they stop for 5-10 seconds and then resume again untill i shut the door, this is repeated until i take out the fuse the remote wire is hooked t,does anyone know whats up?
Old 04-30-2005, 10:13 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
Re: subwoofer feedback pls need help
what did u use for the remote wire (what fuse) it could be one that still gets power all the time, i would just take some of the wire sleeve off of the remote wire on the factory deck or any wire that dosent get power until the cars key is moved to the start or aux position
Old 05-01-2005, 07:57 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Yeah, you might try to fine something else for the amp trigger. It might work as an on off switch for the amp but sometimes they'll backfeed and can do weird things. So, the only fix is to find another trigger point, use a diode, or use a relay to isolate it.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 05-03-2005, 09:49 AM
RedCavalierRacer's Avatar
RedCavalierRacer RedCavalierRacer is offline
Send a message via AIM to RedCavalierRacer
why don't you just hook up the amp remote wire straight to the deck, and string it back to the amp, like it should be?
Old 05-03-2005, 09:31 PM
Nope, can't do that on the newer Gm OEM stereos.
Pioneer 4900mp
Orion C63 Coax rear
Old 05-04-2005, 01:54 PM
oh i didn't see that he hooked it up to the FACTORY deck. my suggestion is just get a newer deck.
Old 05-04-2005, 02:28 PM
KustmAce's Avatar
KustmAce KustmAce is offline
Grande Boleros de Fuego
Ghosts.
MAKE ART, NOT WAR
