Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 04-30-2005, 09:52 PM
67trepid 67trepid is offline
2.7 vs 3.5 engine swap
I have a rod knocking in my 99 Intrepid 2.7 engine. I have an opportunity to buy a 3.3 from a Dodge Caravan. Can anyone tell me whether those two engines are interchangable? What do I need from under the hood ie: computer, wiring harness, etc.
I posted this question on the Dodge forum and didn't get a response. Hoping I would get a responce here.
Thanks, jfc
Old 05-01-2005, 11:15 AM
Bizzy102 Bizzy102 is offline
Re: 2.7 vs 3.5 engine swap
These engines are not interchangable. The caravans 3.3 engint is transverse with the transmission. The Intrepieds is longitudenal with the trans. Two diffenernt things.
Old 05-03-2005, 11:54 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
In first generation Intrepid's, they ran a 3.3 liter, 1998-2004, they had the 2.7 liter. Bizzy102 is right, it's not going to work, if you had a '97 Intrepid, then yes, same motor just needs mods to the intake manifold. Depends on how much money you have available but there are a few options you have: 1) find another 2.7 liter and stick it in their; either rebuilt, brand new, or used [personally, I wouldn't go used, it could be in worse shape then your engine currently is] 2) Get a 3.2/3.5 liter motor and stick that in there. You'll need to do some mods as well, like reposition your A/C compressor, power steering pump, you'll need a new computer and that should work for you.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 04-07-2007, 06:27 PM
gfd111 gfd111 is offline
hi every one ,
first time posting long time reading....
so would a 1999 intrepid 2.7 fit in a 1996 concord w/originally a 3.3 engine???
got a bad crank in the concord and an intrepid sitting in my driveway with a bad tranny.....
sure would be nice if i could swap them!!
thanks in advance
Old 04-14-2007, 10:49 AM
wafrederick wafrederick is offline
Banned
You can use the 2.7 computer with the 3.2/3.5 conversion.I have done it this way with no check engine light on after hearing it run.Tha radatior is differant too.The 3.2/3.5 radatior has oil lines going to the radatior,The 3.2/3.5 throttle cable is longer and the heater hoses are differant too.I have ran into this too.If you replce the computer with a new one,you do not have to go to the dealer.The Mastertech scan tool from Vetronix will program and burn the vin in the new computer.Here is Vetronix's website, www.vetronix.com
