Old 04-30-2005, 09:09 PM
biv343 biv343 is offline
Borg Warner Trans Question
Maybe someone out here will know this. I've got a 69 Javelin, 343, Borg Warner 11B trans. Are there any companies out there that make aftermarket torque converters for these, or any companies that can modify an original? I'd like to have a higher stall speed converter (stock is just too damn low in my opinion).
Thanks in advance.
Old 05-11-2005, 07:16 PM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Re: Borg Warner Trans Question
The B-W auto is generally considered undesirable for performance use. Do some looking, there was a lot of AMC's equipped with a 727 Torqueflite that will accept any standard 727 parts, from torque converters to shift kits to stronger gears, etc. etc..
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 05-12-2005, 09:06 AM
Trust me, I thought of that. Problem is that bellhousings/bot patterns changed in 72 when they went to the 727 transmissions. Cranks (from what I hear) are different as well.
The BW trans works fine, and was rebuilt less than 5000 miles ago (before I bought the car). I don't have any complaints about it other than wishing the stall speed was a bit higher.
Should have bought a car with a manual trans, I guess.... Those are more fun to drive anyways...
Old 05-17-2005, 08:47 PM
News to me, I am pretty sure bolt patterns are the same all years....
Freedom Isn't Free.
Old 05-17-2005, 08:53 PM
OK, did more research. You're partly right. '72 still had the same bolt pattern, you have to machine the crank for an adapter to use the torqueflite.
Freedom Isn't Free.
