Old 04-30-2005, 07:54 PM
rental blazer rental blazer is offline
Exclamation rear side window removeal help SOS
i need a new rear window and found one in the junk yard for a good deal i need someone to tell me how do you remove sideing rear window unit (the whole unit) off the s10 blazer 2 door in the pick a part without braking it
Old 04-30-2005, 11:59 PM
rbuck rbuck is offline
Re: rear side window removeal help SOS
some people use a small steel wire.I had a front windshield and side glass put in for 150.00 had the side glass from wrecked s 10 i purchased whole they remove the used one i cut the broken one out
Old 05-01-2005, 12:35 AM
Re: Re: rear side window removeal help SOS
okay but this is the sliding rear side glass on the 2 door i need to remove without braking
well okay more speficly how do i do it and where do i get steel cutting wire how do i get it trougth the chulking thanks for all the help i know this sounds dumb but i want to know everytheing before i go so i can get it before someone else
Old 05-01-2005, 04:00 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
If you've never had experience doing this, I would just bring it to a local glass shop. When I swapped from solid quarter windows to the sliders, the local glass shop only charged me 35 for the job.
Old 05-01-2005, 04:03 AM
i plan to do that BUT I NEED TO REMOVE THE SLIDER GLASS FROM A BLAZER IN THE PICK A PART YARD thats what i need to know how to do
Old 05-01-2005, 05:24 AM
rlith's Avatar
The easiest way for that is to remove the inner plastic panels around the window then take a propane can with the torch nozel on it and melt out the adheasive... They will clean it up and put a new gasket on it when they install it.
Old 05-01-2005, 01:06 PM
not smart that the uneven heat will brake the glass
Old 05-02-2005, 04:19 AM
rlith's Avatar
I've done it plenty of times, and that's also how most wrecking yards remove it. (Where I learned how)... You obviously have to be careful, but there is no prob melting the glue.
Old 05-02-2005, 05:39 AM
blazer94's Avatar
blazer94 blazer94 is offline
If you have access to a heat gun, use it to melt the adhesive from the inside after removing the plastic panels, as rlith said. I did that on my 95 2 door to replace my rear quarter window, worked like a charm. used an awl to score the adhesive as i worked the heat gun, and duct taped large strips to the outside to keep it from falling to the ground as I was working alone. I also had a large pile of newspapers crumpled up underneath the window, but the tape worked fine.
Trailblazer 2005.
2WD LS
Brand new, No Mods Yet!
Old 05-02-2005, 12:38 PM
well it took me 1 hour and ahalf to do the side in the shade and 45 min to do the side in the sun so i guess i shouldda brougt a propane torach with me however a heat gun would work at home but not in a junk yard where do you plug it in??????
Old 05-02-2005, 03:26 PM
blazer94's Avatar
I ran an extension cord to the outside outlet, no problem. Our pick n' pulls in chicagoland are pretty well organized...
Trailblazer 2005.
2WD LS
