Old 04-30-2005, 05:45 PM
Tikiman's Avatar
Tikiman Tikiman is offline
Decal softener?
Is this the stuff that softens the decal and makes it conform to the shape of the object being decalled?
http://www.hlj.com/product/GNZMS-232
Also do you need any other liquid for the job?
Thanks.
Old 04-30-2005, 05:51 PM
Feint Motion's Avatar
Feint Motion Feint Motion is offline
Re: Decal softener?
No, That is Decal Set, It sets the decal inplace. You need the solution stuff. You might want to do a search to get more info. Thats how I Learned.
~Josh~
OldUser:IImportSupra
Do You Have a Car that Goez Sideways?
Old 04-30-2005, 05:53 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Re: Decal softener?
Microsol is decal softener, microset sets the decal like the stuff in your link.
-Mike
Old 04-30-2005, 05:54 PM
PlumbedandWired's Avatar
PlumbedandWired PlumbedandWired is offline
That's the setting solution. You put this down on the surface you want to decal before putting the decal on. Then you paint some "Mr. Mark Softener", "Microsol", etc. on the decal which will make the decal conform to the irregular surface.
Doesn't look like HLJ sells Mr. Mark Softener however, if you want to get something from HLJ, this'll probably do the trick (though I haven't used this before).
Old 04-30-2005, 07:16 PM
Tikiman's Avatar
Re: Decal softener?
Thanks for the help guys.
Old 05-02-2005, 07:37 AM
Sticky Fingers's Avatar
Sticky Fingers Sticky Fingers is offline
Re: Decal softener?
Can I just add:
DO NOT USE MICROSOL ON TAMIYA DECALS - THEY WILL MELT!
Thank you
Old 05-02-2005, 10:00 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
All you need is Mr. Mark Softer. It does the job great all by it's self... - Mark
Old 05-02-2005, 10:07 AM
Vric's Avatar
Vric Vric is offline
Re: Re: Decal softener?
Originally Posted by Sticky Fingers
Can I just add:
Thank you
Isn't what we want when we use Microsol ?
I use Microsol a lot and Tamiya decal included.
Old 05-02-2005, 11:29 AM
proosen's Avatar
proosen proosen is offline
Re: Re: Re: Decal softener?
Ditto!
I've had no problems what so ever with Microsol on any brand of decals! Just don't use it when it's not necessary as it can wrinkle a decal applied to a flat surface never to get flat and even again! Trust me I've tried that one to
Niclas
Edit:
You can get Microscales product's at MJ-Hobbyexperten just click "provhandla" and then "gästkund" and search around for Microscale, they go for 37 SEK a piece. The site is somewhat hard to navigate but it's there if you are persistent
Old 05-02-2005, 12:03 PM
Re: Decal softener?
Well, f**k me with a knobbly piece of styrene! It's so funny how this site is a source of many contradicting answers!!! I remeber reading on this site never to use microsol on tamiya decals as it will ruin them! Glad I now find out they're okay - not long till I'm putting my decals on my Focus WRC 01.
Many thanks for correcting my stupidity!
Old 05-02-2005, 02:32 PM
Vric's Avatar
It's not stupidity. a Mistake is a Mistake. Everyone makes mistake, but few are stupid
Those that say it don't work it's because they don't know how to use Microsol.
Yes, Tamiya decal react more than other decal to Microsol, but if you apply it and leave it dry (as you always should) it work perfectly. If you start to play with it, then YOU will ruin the Decal. It's not microsol, it's the user that ruin it.
Old 05-02-2005, 05:06 PM
Amazon's Avatar
Amazon Amazon is offline
Re: Decal softener?
You guys should try Microsol/set on Hasegawa-decals,`cause they don´t react to anything..
( unless you let the decal literally swim in solution )
Newsflash: Diecast sales fund terror activities.
Old 05-02-2005, 05:14 PM
RallyRaider's Avatar
Zomby Woof
Re: Decal softener?
No matter what decals or type of softening solution used, you need to test compatibility first. Microsol will eat some Tamiya decals, other times it will have virtually no effect. Blanket generalisations will always have exceptions. Test first and be sure!
