rusty rockers
anyone replaced the outside rocker panel on there 4 door blazer ?
mine are going under the front doors. is this a weld in part or what? |
Re: rusty rockers
Have you considered finding a replacement door as a whole.
Once the rocker has rotted, the rust is throughout the door on the inside.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: rusty rockers
They are weld in parts, not difficult to replace. You can usually cut out the old sections with a grinder and weld new ones in place. If you want to "hal a$$" it, you could always weld the new one over the old one. JC Whitney used to ( and may still) make really cheap flimsy ones just for that purpose. |
Re: Re: rusty rockers
Re: rusty rockers
Ouch, you may be right, I must be thinking of the lower door skin.
Dammit.....
Re: Re: Re: rusty rockers
Maybe we have a terminology conflict. What you are calling rocker panels, I would call lower doorskins. Take a look at this link. http://www.minitruckinweb.com/tech/0306mt_rocherrepair/ To the original poster - if you have the rust on the bottom of the doors, take BlazerLT's advice and get new doors. If it's the "other rocker panels that live below the door" then you can replace those fairly easily. Lower doorskins can be replaced provided you're just dealing with surface rust that hasn't eaten too far through. |
Re: Re: Re: Re: rusty rockers
No problem BlazerLT - I believe you've corrected me a time or two in the past. I've replaced enough rotten sheet metal in my life (thanks to the Michigan Department of Transportation, who uses no less than 100 pounds of salt per mile per snowstorm in the winter months).
OK, that might be a bit of an exaggeration, but not much.... I will be replacing rotten rocker panels on my old S-10 here in the future if the weather ever decides to get warm and stay warm. |
Re: rusty rockers
I think we are both right:
Rockers = Portion under door Rocker Panels = Lower door skin
Re: rusty rockers
You can buy rocker panels seperatly. They are a weld in part. Check with Pa collision parts in Zelinople PA. (use whitepages.com for the number)
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
