Old 04-30-2005, 05:20 PM
sevie8 sevie8 is offline
'92 5.7 -- Surge/chuggle or hesitation? More info
Still working on this -- HELP, Chevy guys! No trouble codes set. On hot start only, I have a surge and then stumble on move off. Also have it on light throttle cruise. After increased throttle it doesn't occur. Things done -- new fuel filter, PCV valve, distributor cap, rotor and spark plugs. Timing set to specs. EGR valve clean, holds suction, EGR solenoid works and holds suction. Swapped in old O2 sensor (which worked fine) and problem still there. NO vacuum leaks found.
When I disconnect the EGR valve and plug the solenoid valve port to the EGR, the chuggle is gone (Of course, the motor pings then, so I can't use that to fix the problem!)
Disconnecting the IAC stops the problem, but lets the idle speed run a little too high.
Any ideas?? Thanks, Sevie
Old 07-09-2005, 11:06 PM
mountainboy mountainboy is offline
i had the same problem almost but i was road hunting a coondog and my truck would surge when barley giving it gas. Turned out It was the egr. If you got the money try it. You may be surprized.
Old 01-08-2006, 09:13 PM
animal2000 animal2000 is offline
gee i have the same problem maybe..hesitates at slight throttle;;at 35mph with a342 gear..it will start surging..unpluged the egr solinode and it runs fine,,but ..no codes,,this does it hot ;cold it runs like new ..its a 92 ck 1500 with 96000 miles bought new..been having this for 3 years ..get worst in winter..everthing has been checked..bad egr? about to drive me nuts.keeps taking me back to cat or egr..going to put avac gauge on it mon..
Old 01-08-2006, 10:33 PM
fatmacsumo fatmacsumo is offline
Send a message via Yahoo to fatmacsumo
Re: '92 5.7 -- Surge/chuggle or hesitation?
if egr is bad it will set a code most of the time
but can still cause a problem did you perform a vacumn test with the egr on the veh when it is hot
you do this with a vacumn pump if it skips when you pump it up gradually then let off vacumn and it
stops skipping possible ok. explain hot start only
usually when it gets hot you may have elec.problems possible distributor or tps i need more info like does it do it when it is cold and how far do you drive before you notice this happens
Old 01-08-2006, 10:55 PM
hey animal you may be on the right track if you change the egr replace it with an original gm part
not after market it has been my experiance that it will bite you in the butt.also call some shops and
see if they use bg products for a fuel injection serv
after you put on your new egr you can do this before you purchase the new egr it may possibly clean the old egr and the ports to the unit
Old 01-09-2006, 02:17 AM
the egr has never been off..ege truck runs ok cold,,starts to run rough at stop in gear.then it will smothout as it warms up..but at 195 degit will be hesitent ..you have to hot rod the truck to drive it . .unplug the egr sol and it ok just s bit dogy but i know the ecm is retarding the eng.i have a 350 .700r4x4 thanks
Old 01-09-2006, 09:24 PM
easy check you need to make look to see if your map sensor is hooke up and is getting vacumn the egr will cause an internal vacumn leak so it effects
the map sensor & iac [ idle air control] the way you check for vacumn leaks use a can of carb cleaner
that has a small straw.you can buy at any parts store.the firt thing you do is take of breather with the engine running spray some in the throttle not a lot it will shut the engine off if the engine idles better you have a vacumn leak somewhere spray some around the egr if the engine idles up some
replace also spray around other parts of your intake
be care ful not to spray to much around the distributor it will start a fire use little burst it will help you find vacumn leaks
Old 01-12-2006, 08:25 PM
ok got it fixed..egr valve and new solenoid..gm part no on the sol is14102002..my egr is17113371..the truck now runs like the day i pickit up new..now i am ready for a big snow...thanks for all the help..need any help on corvairs feel free to email me..
Old 01-12-2006, 08:31 PM
it feels great to help and i am sure you are proud of repairing it your self good work ani2000
