Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 04-30-2005, 03:13 PM
fbi-interceptor fbi-interceptor is offline
Send a message via Yahoo to fbi-interceptor
anti-lock problem
IVE HAD MY P71 FOR ONLY ABOUT TWO WEEKS. I HAVE A ANTI-LOCK LIGHT THAT COMES UP ON THE DASH DURING STARTUP AND WILL STAY ON PERIODICALLY. BUT WHAT IS WIERD IS TWICE WHILE COMING TO A STOP THE BRAKE PEDAL MADE A VIOLENT PULSATING NOISE, THE PEDAL SORT OF RAISED UP IN PRESSURE AND VIBRATED FOR ABOUT TWO SECONDS THEN IT STOPS. I DONT KNOW IF THIS IS A WARNING FEATURE FOR MY BRAKE SYSTEM OR WHAT. HOW DO I FIND OUT WHAT PROBLEM IS, AND HOW DO I FIX IT. PLEASE HELP!!!!!!!!!!!!! 1993 p71
Old 04-30-2005, 07:08 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: anti-lock problem
Have a scanner that can read the ABS coses retrieve the code. Also if someone has a scanner that can read the wheel speed sensors, you can compare the speeds of each. You can also pull the wheels and rotors and measure the air gap etween the sensor and tone ring. The gap should be about .040 inch.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 05-01-2005, 12:06 AM
cougarman cougarman is offline
Re: Re: anti-lock problem
Good old way2old is right on with the answer.
What you're feeling is the ABS coming on because the system is detecting wheel lock up.
