Old 04-30-2005, 02:01 PM
p--sed chevy owner p--sed chevy owner is offline
de frost heater control
The vacum pump that controls the heater and de froster will only work in the window defrost and vent modes only. Looked at the vacum pump it moves when the knob is turned only in two settings. Should it move to 4 settings based on the control settings on the dash?
Old 04-30-2005, 04:54 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: de frost heater control
Vacuum pump?
The controls run off of engine vacuum.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-01-2005, 06:37 AM
ricksza's Avatar
ricksza ricksza is offline
I'm assuming that you have C60 option HVAC.
You must be referring to the mode actuator under the dash on the heater box. There are two vacuum hoses going to it (yellow and brown). Yellow should have vacuum to it in all but the following settings: MAX, NORM, BI-LEV & VENT. Brown should have vacuum in the following settings: MAX, NORM & VENT. If one of these is wrong, you have a bad mode control switch.
