| Cavalier Problem Diagnosis Got a problem you can't fix? We can help. |
1998 z24 sputtering.... help
NEED HELP....my engine light is not on... the car runs fine if i don't give it much gas through all the gears.... but if i want to drive a little faster it sputters... i really can only push the pedal a 1/4 of the way down if i dont want it to sputter ... i changed the plugs and fuel filter... any suggestions of what it might be??? Vacuum leak? or Timing??
Z,
Could be any number of things wrong. Just because the check engine light isn't on doesn't mean there isn't a code in the computer. I'd take the car to one of the parts stores that will read the computer for free (Autozone, for example) and see if there are any trouble codes there. There are too many possibilities without knowing more. Here's a list of some of them. Your car may not have all of the items listed... Bad coil Arcing plug wire Crank sensor O2 sensor Mass air sensor MAP sensor Clogged air filter EGR valve Vacuum leak Throttle Position sensor Computer Steve |
Re: 1998 z24 sputtering.... help
Or a clogged Cat
1992 Chevrolet Cavalier Z24 *R.I.P.* 3.1L MPFI (3.1 6cylinder Pushrod 12V) 1997 Chevrolet Cavalier Z24 *R.I.P.* 2.4L "Twin Cam" (2.4 4cylinder DOHC 16V) 2003 Honda Accord EX V6 - The new hotness |
