Old 04-30-2005, 10:31 AM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
what is ported or porting????
i hear people talking about that but i dont even know what that is.
Old 04-30-2005, 01:29 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: what is ported or porting????
enlarging the size of the opening. for example a ported 2g o2 housing is a stock 2nd gen o2 housing that someone used a carbide bit and air grinder and ground out bigger so it would flow more
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 05-02-2005, 10:39 AM
Re: Re: what is ported or porting????
could u do that to a turbo and the headers
Old 05-02-2005, 12:32 PM
MoozillaGSX's Avatar
MoozillaGSX MoozillaGSX is offline
Send a message via AIM to MoozillaGSX Send a message via Yahoo to MoozillaGSX
yes
Austin - 95 GSX .
-K&N FIPK.
-Ijnen UICP + Greddy RS BOV.
-Rota Slipstream + yokohoma Es100's.
-Tokico HP Blue's + Springs.
-Power Slot PRO rotors ( slotted+Dimpled ) with Hawk HP Pads.
-Manacore Wires.
( got a 20g and the works in the clothset )
Old 05-02-2005, 02:17 PM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
Lots of people do as a matter of fact.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 05-03-2005, 10:18 AM
what all can i do that to.
Old 05-03-2005, 12:41 PM
ted_ex's Avatar
ted_ex ted_ex is offline
You can port anything air flows through. Of course it's fairly complicated when you get into head porting and agressive porting of parts. You also have to be careful about porting to large and making the walls to thin. for basic porting including pictures check vfaq.com for some good info.
tedX
I'm>everything
