Old 04-30-2005, 09:12 AM
ponygt99 ponygt99 is offline
My hood will not lock in place please help
I have a 1999 Mustang GT and I popped the hood at work to check the coolent levels and when I go to close the hood it refuses to lock in place. It has been having problems closing but it would always lock on the second try? Is there anything I can do to fix this as my car is parked outside my office?
Old 05-01-2005, 01:18 AM
stang_racer20's Avatar
stang_racer20 stang_racer20 is offline
Send a message via Yahoo to stang_racer20
Well first make sure you didnt somehow lock the latch w/o the hood closed. Then try lubing it up real good as it may be sticking. Also make sure the release lever is pushed back in all the way, cause when they get stuck the lever sticks out and wont allow the hood to close. If none of those work, its time for a new latch.
92 Mustang GT, 347 Stroker(Forged Steel Crank/Rods-Balanced, Forged Alum Dished Pistons), B50 Block, Track Heat Intake, Twisted Wedge Heads w/ Stage 3 port/polish, 80mm C&L MAF, FMS 30# Inj., BBK AFPR, Trick Flow Stage 2 Cam, Trick Flow 1.6R Rockers, BBK EL-CC Headers, MAC O.R. H-Pipe, Flowmaster Cat-Back, Accufab 75mm TB, MAC CAI, BBK Pulleys, Griffin Alum Radiator, Mark 8 Fan, MSD Pro-Billet Distributor; AOD, Dynamic 3300 L-U Converter, B&M Trans Cooler; 3:73 gears.
Old 05-01-2005, 07:18 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: My hood will not lock in place please help
or hood pins..
1969 Cougar
357w & TKO - 475hp
