Old 04-30-2005, 12:55 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Talking swap questions
ok i have several questions concernen the small block 350 swap i am getting ready to do:
i know i need the computer, im going to use an obd I computer instead of my obd2 that is currently on the truck (98 and the block is a 92) how hard will the intereor lighting be, ie my indicator for shift is digital
the block was sold as a short block, any suggestions on something good i could pick up from a junk yard (overboard i looked into that company and i had a buddie of mine tell me that it would be atleast a grand) can i cross aluminum heads with the cast iron block? im wanting to do some old camaro or vette heads (by old im meaning 92 or newer), but if its going to cause more headach then reward, its not worth it to me
transmission, should i use a 700r4 or a 350 turbo? it will be close to a daily driver, so im not as concerned about speed as keeping my miles to the gallon in the double digets
and will my accesories from my 4.3l work on this block? i mean going from a 98 4.3 to the 92 5.7, the alternater, oil pump, water pump will work right?
And finally, it was originally a tb setup, should i just get the tb manifold, or would something "better" fit, i know better is an opinion, but im wanting more of a multiport over a tb
TIA to all
Doug
Old 04-30-2005, 12:44 PM
toenailclippers toenailclippers is offline
Send a message via AIM to toenailclippers
Re: swap questions
700r4. cheaper to build and more reliable
Old 04-30-2005, 01:22 PM
Re: swap questions
thanks a bunch, now the hunt for the 700 begins!.... can anyone tell me, how do i tell the difference between a vortec and non vortec moter? the casting numbers, with all ive been able to find tell me 4 bolt main, made in canada
Old 04-30-2005, 02:59 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
Re: swap questions
if youre looking for one still in truck it will tell you in the vin. w- for non vortec and z for vortec. i hope that helps alittle.
not for sure how they are marked on the motors themselves. if you find out let me know.
Old 04-30-2005, 03:01 PM
Re: swap questions
yeah, moter was bought re-done by a shop, and they are turning out to be little help, im going to e mail them monday it seams my 4 bolt main is a 2 bolt main... the only way i can think of to get the vortec or non vortec answer from the block is the casting numbers at the dealership
Old 05-16-2005, 05:02 PM
kajunrrick kajunrrick is offline
Re: Re: swap questions
The W and Z has nothing to do with if it is a vortec. The W was a high end more HP w/cpi intake. All S10 & S10 Blazers 92 & later 4X4 had the W motors. Vortec engines came out in 92, vortec heads came out in 95. You will find the block# on the right side that will tell you if it is a W or Z engine.
A 834#is a W engine.You can find this on any site that has chevy block#s. Hope this helped. I am putting a 3.8 series 2 engine in a 92 Blazer, it came out of a 97 Camaro. With afew mods this little engine is at almost 300HP, But still on hiway miles great on gas!
Old 05-16-2005, 08:45 PM
balls_to_the_wall's Avatar
balls_to_the_wall balls_to_the_wall is offline
Re: swap questions
300hp, holy horsepower batman, aren't those things rated at 230 factory....What "few" mods did you do, a turbo????....I am not doubting you, I'm just curious.
Oh and use the 700R4 of you want milage, it has 4 gears instead of the Turbo-350's 3 gears....
Later
-Ryan
Old 05-17-2005, 06:47 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
I'm doing the 5.7 vortec swap within a month... Sticking with an ODBII ecm. (using a k1500 ecm and harness). It's damn near plug and play. DM, the problem with using an ODBI ecm is your gauges.. an odbi ecm will not drive the 98 gauges because the gauges rely on the bcm and ecm/pcm to drive the signals. If you're going with an odbi ecm, check dakota digital for gauges. They do custom work that will fit in your existing dash. Be aware as well that in the US disconnecting the airbags like that (odbi won't drive your airbags) is illegal. (not saying people don't get away with it every day). If you're going with a vortec, get the 98/99 escalade harness and ecm, it will be a plug and play deal, same if you get an lt1 motor...
Old 05-17-2005, 06:56 AM
Later
-Ryan
yeah, around 230, ive put flat top pistons in, got 58cc cumbustion chamber cylender heads, haven a cam ground for my by either gm or comp cam, callen them and tellen them EXACTLY what im running from the breaks to radio, and they can get me to where every thing will be able to be on/running and me not stall out. im also getting injectors from a corvette and timeing gears, those are for the nois though. rlith, i wound up getting a 96+ intake setup, so ill be using obdII also, if you run into some searious problems, let me know, so i can avoid them
Old 05-17-2005, 07:00 AM
rlith's Avatar
Re: Re: Re: swap questions
Just get the matching harness and you should be fine... What motor are you using?
Old 05-17-2005, 09:38 AM
Re: swap questions
the block is an 87+ and the heads are 96-99 vortec heads, intake manifold is from a 97 p/u
Old 05-17-2005, 01:49 PM
rlith's Avatar
Re: swap questions
definatly want the 98-2000 ecm and harness then...
