Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-30-2005, 12:20 AM
Claire1973 Claire1973 is offline
Air mass meter/air flow meter/dishonest mechanic
I have a '99 Honda Passport with about 54,000 miles. My car has been having trouble with it's timming(?) idle(?). The RPMs seem to have a mind of their own, sometimes going really high, more often though,going low & the car shuts off. The problem is intermitent, can happen when I first start the car or after I've been driving for hours. I had it checked out,the mechanic said there were probably carbon deposits that needed cleaning. He did this, but it didn't help. Then, the Check engine light came on and I took it back, he said that the Air Flow Meter needs to be replaced. Anyone had this problem? The thing is, I no longer trust the mechanic because he said a new Meter would be ~$500, but they were looking for a used one for me that would be ~$200-$300. I looked online and NapaAuto sells air mass meters NEW for under $300. Is an air mass meter & an air flow meter the same part? The car is scarry to drive because I never know when it will shut off. Any thoughts on either the car problem or the mechanic?
Old 04-30-2005, 10:23 AM
Cat Fuzz Cat Fuzz is offline
I'm not sure about your problem, but if you suspect this mechanic get a second opinion from another shop. Repair shops will always charge you more for parts than you would pay if you bought them yourself. This is normal.
Old 04-30-2005, 10:43 AM
Dober89 Dober89 is offline
Re: Air mass meter/air flow meter/dishonest mechanic
Has anyone mentioned the intake manifold gasket? My rodeo did the same thing at around the same mileage and it was the gasket.
Old 04-30-2005, 01:57 PM
marcre's Avatar
marcre marcre is offline
Send a message via AIM to marcre Send a message via MSN to marcre Send a message via Yahoo to marcre Send a message via Skype™ to marcre
Re: Re: Air mass meter/air flow meter/dishonest mechanic
Agreed, IMG is my guess. Same symptoms I had, took a while for my mechanic to diagnos it.
2007 VW Jetta 2.5 5sp
1999 Rodeo LS 3.2 4x4 SOLD, but not forgotten
My Rodeo
