Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-29-2005, 08:24 PM
LenXIII LenXIII is offline
high idle PLEASE HELP ASAP
When I start the car the idles go real high (upto 5000+) and stays there, it drops a little but stays pretty high. I tried pull a sensor on this airbox looking thingy and the idle went even higher and then back down when i put it back in, but still idles real high. Whats the usual problems that cause high idle?
Old 04-29-2005, 09:21 PM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: high idle PLEASE HELP ASAP
What year what motor?
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 06-23-2005, 09:32 PM
Crash871 Crash871 is offline
I too have this problem, on my 1997 T-Bird V6 3.8L engine. It has been happening ever since I first got the car, only now as it is getting older it is starting to become more frequent. It is a totaly random thing, it does it when it wants to. The car has 122,000 miles and has been regularly maintained.
I noticed it when I first start the car in park, the tach needle quickly shoots up to about 2,000-3,000 rpm. Then when you put it in gear it drops to 1,000-1,300 RPM but not without a violent jerk and a rough idle when I get in gear. Once it is in drive, I have to put more effort into the brake pedal becuase it wants to lurch foward and run on its own. There is no check engine light when it does this.
I have tried using different octane levels and brands of gas, replaced my MAF, replaced my spark plugs, replaced my O2 sensors and nothing seems to work.
If anyone could help it would be greatly appreciated because it is starting to become a serious safety issue.
Old 06-24-2005, 05:49 PM
97Bird's Avatar
97Bird 97Bird is offline
Hot knowing much about the car, it sounds like a throttle positioning sensor problem and/or vacuum leak.
Old 06-24-2005, 08:00 PM
Re: Re: high idle PLEASE HELP ASAP
I have checked for vacum leaks and none were found. I havent checked the throttle positioning sensor yet, but I will give it a stab if possible.
Old 06-24-2005, 11:22 PM
SUERED SUERED is offline
Hey,
Our '88 Bird had accelerating/ high idle problems--hard to brake, etc.. (V-6 3.8). Ford dealer could not help. Took it to a local specialty shop known for electrical systems. They cleaned the injectors and told us that injectors get partially fouled and then the computer over compensates---and you get this problem. Problem solved by having the injectors cleaned at the rail. You can buy a kit for about $40 if you are savvy enough to do this work. It cost me much more at the shop. They used a cleaner I think called 44K --I still have the can. Did our other '89 Ford as well. This was over 5 years ago--no problem since.
Old 06-25-2005, 05:03 AM
corder13 corder13 is offline
Send a message via ICQ to corder13 Send a message via AIM to corder13 Send a message via MSN to corder13 Send a message via Yahoo to corder13
One problem I had on a '90 Grand Marquis with a 5.0 was the PCV valve came out of the back of the engine (not in the valve cover on my car, was in the middle of the back of the motor). It took me a day or two to find the problem. Once it was back in, it idled normally. The only difference is mine was probably only running about 2000-2500 RPM, not 5000.
Rick
Old 06-27-2005, 11:12 PM
forcfed93's Avatar
forcfed93 forcfed93 is offline
This is a common problem with our cars. It sounds like the Idle Air Control Solenoid. To check it, Remove the wiring and turn the IAC 1/2 of a turn and replace it. (Note that the wiring CAN NOT be plugged back in when it is installed this way).
Then start the car. It should reset the idle and you can then limp the car around until you can get it replaced.
Michael Albee - Prez
Super Coupe Club of IOWA
http://www.sccoia.org
1990 XR7 Auto
1991 SC Auto
1993 SC Auto
1993 Mark VIII (a.k.a. "The Winter Beater")
Old 06-28-2005, 01:06 AM
Donald91tbird Donald91tbird is offline
Send a message via AIM to Donald91tbird Send a message via Yahoo to Donald91tbird
where is the IAC located? pics would be appreciated , thank you
Old 06-28-2005, 08:24 AM
forcfed93's Avatar
It's mounted to the top of the Throttle Body with two 10mm bolts. (On an SC it's on the side). I'll see if I can find a photo, but you cant miss it. It has a small plastic connector (2 or 3 wires) pluged into it.
1990 XR7 Auto
1991 SC Auto
1993 SC Auto
