Go Back   Automotive Forums Car Chat > Fabrication & Tools > Other
Other Other fabricating topics.
Old 04-29-2005, 07:12 PM
wrxfreak123 wrxfreak123 is offline
convertin to an awd
ok this would be in the fabrication forum kinna. is it possible to convert a rwd car to an awd. if you had the awd front and rear axles,transfer case, and stuff like that. i would have to custom make the driveshafts right? is it possible to do this and mount it to were ground clearence is not an issue? what would i need to make myself to make it work? thanks guys
Old 04-29-2005, 07:39 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: convertin to an awd
you'd have to custom build all the driveshafts and places to mount everything, as well as find a way to make the Front hubs that are connected to halfshafts fit in the place of where there were hubs with no shafts, There's also a good chance there isn't enough clearance under the engine in the front of the car for the front diff. This would be VERY hard.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 04-29-2005, 07:59 PM
that hard? dang so it would be possible but very hard right? if i did do this then i could make all the stuff like mounts and driveshafts. so if i can get the front hub up what else? would i need to use the whole suspention from the car i got the awd system from? what else would i need after that? thanks for your imput it helped alot
Old 04-29-2005, 08:17 PM
drdisque's Avatar
it depends whats different on the cars you're using, there's a chance you could get the FWD/AWD hubs to fit, there's a chance not, you might want to use the front suspension off another car and then fabricate all the mounting points.
Dr. Disque -
Current cars:
2011 Mazda2 Touring
Past cars:
Old 04-29-2005, 08:49 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
It would be very difficult. There would be a lot of fabrication involved. And to get it all designed properly is a whole 'nother challenge.
-Mike
