Old 04-29-2005, 06:28 PM
hmenzel hmenzel is offline
Battery Removal 2000 Lumina
This battery has a cover with what looks like 2 clips. I can open the one back toward the windshield, but the other one is under a wiring harness and what appears to be a fuse holder. Can this be removed to get at the battery? I need to charge or replace it.
Thanks.
Old 04-29-2005, 10:03 PM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Battery Removal 2000 Lumina
I don't know if yours is the same as my '97 or not. Battery is located behind driver's side headlight. You have to remove the core support brace, winshield washer tank, and a small power junction box to access it. To charge the battery, there is a jumpstart terminal located over the left wheelwell, should have a red cap over it that you pull off, then there is a lug you can put a charger on (pos). The negative can be connected to any bare metal part of the motor.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 04-29-2005, 10:05 PM
I have a feeling you are looking at the cover over the computer on the passenger's side?
...empty gun rack.
Old 04-30-2005, 04:35 AM
Re: Re: Battery Removal 2000 Lumina
It is on the passenger side and is as large as the battery might be, but I will check. (The car is my father-in-laws, is 60 miles away, and he is in a nursing home now.)
I will also look for the charging lug, since that might be all I need.
Thanks.
Old 05-03-2005, 08:57 PM
k5dan's Avatar
k5dan k5dan is offline
Send a message via Yahoo to k5dan
I hated those when i worked for aaa
-->1994 Ford Thunderbird LX 4.6l V8, auto trans. Completely Stock
-->1989 Dodge Dakota 3.9l v6, 5 speed manual trans, 4x4
