Old 04-29-2005, 05:30 PM
xdurianx xdurianx is offline
Need help deciding which amp.
I have 2 12" RE's, and I'm trying to find a good budget amp for them.
My budget is $150max..
I've been looking on ebay...and I found some in my range...
MA AUDIO M589I --------$108
Number of Channels: 2
RMS Power (4 ohms): 150 watts x 2 chan.
RMS Power (2 ohms): 220 watts x 2 chan.
RMS Power (1 ohm): Not Stable
Bridged RMS Power: 300 watts x 1 chan.
Peak Power Output: 600 watts
Min. Impedance Unbridged: 2 ohms
Min. Impedance Bridged: 4 ohms
THD @ Rated RMS Power: 0.05%
Speaker Level Inputs: Yes
Amp Preamp Outputs: Yes - 1 Pair
Built-in Crossover: HP (50 - 250 Hz), LP (50 - 250 Hz)
Bass Boost: 0 - 18 dB
Signal-to-Noise Ratio: 90 dB
or..
MTX MXA4002 for $132
Power (watts RMS into 2 ohms x channels) 200 x 2
Power (watts RMS into 4 ohms x channels) 100 x 2
Bridged power x channels (4 ohms) 400 x 1
Peak power x channels (watts) N/A
CEA 2006 rated No
Distortion (THD%) at rated power <.025%
Signal to noise ratio (dB) 80 dB
or..
HIFONICS ZEUS ZX4000 for $133
2 x 100 Watts @ 4 Ohms
2 x 200 Watts @ 2 Ohms
1 x 400 Watts @ 4 Ohms
Bass remote with blue LED power on & indicator included
Ultra Fi Mosfets
Zeus EXVP
Hifonics Surface mount design
Fully adjustable accu-cross X-overs
PWM mosfet power supply
Line output for amp daisy chaining
Variable Bass EQ
Sub-sonic filter
I can't decide which one to get...
If you have others that you know, or have experienced and they are good for the price, let me know.
THanks.
Oh, and i'll be running those REs on about 200rms.
Old 04-29-2005, 06:28 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: Need help deciding which amp.
Well, it depends on the subs. Are they DVC? What ohms are they? If they are single coils @ 4ohm then you'll want to look at something in the 2ohm stable area. If they are DVC @ 4ohm then you'll need somethin in the 1ohm stable area.
I was gonna say the HIFONICS amp until I saw the specs. Man, I had a Zeus amp about 10years ago that was something like 1000 watts RMS @ 12v. Man have they really cheapened their stuff.
Sorry, need more info on the subs before I can say. Personally, out of that list, I'd say none of them since they are only 4ohm mono stable.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 04-29-2005, 10:14 PM
the subs are 2 12" RE REs...
they are dual 4 ohms...
what ohms could i go with?
