Old 04-29-2005, 04:04 PM
deker deker is offline
Angry speedometer
hi all the spedometer on my 96 windstar has started jumping when i reach the speeds of about 60 kms . the needle jumps to 80+ and continues to increase the faster i go.
thought it was cable.... noper
turns out it is the cluster.... anyways anyone have an idea of pricing on new one????? and how much of a job is it to replace?
i know i am getting frustrated with the thing!!!!!
Old 04-29-2005, 11:16 PM
CoachKarl CoachKarl is offline
Re: speedometer
This you can fix yourself. . . If you are patient and cognative. 1. Pull the Insturment cluster. 2. Remove the speedometer/odometer. 3. The problem is that the two screws holding the odometer to the speedometer face are loose. I fixed this, but I didn't take any pictures while I did it. I can only explain to you. Shall I go on? (You can pick up a replacement cluster for about $50 at a junkyard)
Karl.
PS. Hope you ask. Tools required at this point are 1. Drill Press.
2. 3/8 " Drill Bit
3. Screwdriver.
PPS. My speedometer used to jump back and forth from 20 to 100 before I attempted to fix it.
PPPS. It's fixed for 40K miles.
Old 11-29-2005, 02:50 PM
jbrandon jbrandon is offline
Re: speedometer
I have a simialr problem on a '96 Windstar. How did you fix this issue?
Thanks
Peter
Old 11-30-2005, 12:02 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: Re: speedometer
Karl.
2. 3/8 " Drill Bit
3. Screwdriver.
My 95 was jumping when I got it. The previous owner's mechanic thought it was the lower cable. The previous owner (po) bought the lower cable but the mechanic said the laber was more than he wanted to spend on repairing the speedo.
When I was driving it, I noticed the shaft for the needle was bouncing around, like it didn't have a bearing.
To make a long story shorter, I got a used insterment pannel from a bone yard for 50.00 and put the head in to my pannel. (I knew my other items worked) I also check and replaced any burnt bulbes when I was in there.
I still have the old head and am working on getting pictures together (of it and other items) in a web page for others to view. I plan on taking it apart and see what did fail.
Regards
Dan
Dan
