Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-29-2005, 03:12 PM
360spider's Avatar
LEAN MEAN - 360 Challenge Stradale Conversion
Ok, this one is for the fans of modern Ferraris! Another one of my recent superdetailed projects. I will attempt to convert Tamiya's 360 Modena into 360 Challenge Stradale street-legal racer using a mix or after market and scratchbuilt additions - MSM Creation transkit, Renaissance transkit, Speed Line BBS wheels, SMS decals, Acu-STion 360 photoetch detail set, and few modifications of my own. I'm sure you are all seen the real car, but here is goes:
As usual, I started with the body - front bumper is completely different on Stradale - so I carefully removed the original one. Rear bumper is slightly different too, so I glued some sheet plastic to modify it a bit.
Rear grille is made from very thin mesh on Stradale, so it was cut out and will be replaced with scratchbuilt grille. I also modified licence plate receptacle in the rear bumper - it is shaped differently on Stradale.
Plastic was shaped as needed, and everything carefully sanded and cleaned. I also glued Stradale's side skirts from MSM transkit.
Finally, I added front bumper from MSM kit, and removed all mold lines and other little flaws from the body - now its ready for the paint.
Finally, I primed the body with gray and then white primers and sprayed few paint mist coats:
Then I finished the paint, polished it out, and filled in the panel lines:
Then I painted window trim, decalled the body, and waxed the whole thing.
<b>Now to the Challenge grille - I decided that the best way to was to scratchbuild it! Here is how I did it:</b>
I bought finest K&S photoetched mesh with round holes I could find. Then I cut a rough shape of the grille:
Using masking tape, I made a template with the location of the taillight housings, and stuck it to the grille. Then carefully working my way through, I cut the openings (lots of filing with round needle files!) and sanded the grille to correct shape.
Then grille was chemically blackened with Blacken-It, and lightly clearcoated to give it this semi-shine. Before continuing, I test fitted it to the body to ensure good fit.
Taillight housings were cut off the plastic part, painted black, and glued to the photoetched mesh. Then I installed the taillights, Cavallino, and Challenge Stradale decal.
Grille was glued to the body, and I started working on the engine lid. As you know, engine lid of Stradale is a bit differen, and features bigger and more pronouced bulge, as well as different vents o nthe sides. MSM transkit supplies this part as a resin piece, but even before assembly I thought that bulge looks way too small. Turned out, the whole part was too small! Look at this gap! It was short too, and kit window didn't fit either. Absolutely useless part! So, I had to make my own...
I built-up the bulge with pieces of sheet styrene, and reinforced the enge with styrene piece.
Then using my pin vise I drilled out the vents and did final shaping with hobby knife and needle files. Turned out pretty nice, and the glass was fitting just fine!
Finally, the bulge was shaped with Squadron putty over the styrene, and refined with sanding sticks. Its in white primer now, ready for final coats of paint.
Sorry for the information overload, I'll try not to update for a while! I hope you like it thus far.
Alex
ItalianHorses.net
Old 04-29-2005, 03:17 PM
SchuberT's Avatar
SchuberT SchuberT is offline
Re: LEAN MEAN - 360 Challenge Stradale Conversion
I hate to be a nit-picker, but it looks like some of the holes in the mesh were filled with the Blacken-It. Will you consider poking them with a needle or something?
The build is great, though. I love it!
Read the FAQ please.
https://www.facebook.com/KBModelwerks/
Call me Matthew.
Old 04-29-2005, 03:18 PM
proosen's Avatar
proosen proosen is offline
Wow!
What can one say but, Wow! This looks absolutly fabulous.
I will keep an eye on this one.
Niclas
mickbench's Avatar
mickbench mickbench is offline
Like it.. I love it. You are a total master when it comes to a super detailed build. I just love the way you give some much detail about what you are doing. It really helps, as I can then use some of the information to help me get better.
Yet again, I'm floored by your superb paint jobs. - BTW, it was your guides I followed to spray my models, and it helped so much..!! Great builds, and great information.
Old 04-29-2005, 04:04 PM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
Another highly detailed stunner of the master. Don't worry about the info overload. I absolutely love that as it explaines so much on how you do things. I'm also planning a Stradale version in red, but it might take a few years before I actually will start it. This thread will really interest me and motivate me to start mine. Keep us posted!
Old 04-29-2005, 04:09 PM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
that paint is perfect!!
"You can go far with a smile, but you can go farther with a smile and a flamethrower"
Keep it Wingless.....
Old 04-29-2005, 04:11 PM
Vitalik's Avatar
Vitalik Vitalik is offline
Send a message via ICQ to Vitalik
Awesome!!!! I'll follow this thread no doubt!!!!
(hmm... it seems I said something incorrectly... nevermind! I'm so impressed with Alex's bulding, that can't say it in English)
Zdorovo!!!! Na nashih glazah rojdaetsya ocherednoy shedevr! Eto klassno! Uspehov i jdu prodoljeniya!
Old 04-29-2005, 04:31 PM
willimo willimo is offline
Sweet, sweet tiny Hondas.
Gorgeous to the MaX!
Old 04-29-2005, 04:47 PM
ThatRoundHeadedKid's Avatar
ThatRoundHeadedKid ThatRoundHeadedKid is offline
Fantastic! I love how modelers paint and clearcoat all their plastic models to make them look like they're metal.
Ride #1: 1994 Mercedes-Benz W124 E320 Coupe (My first car/love)
Ride #2: 1975 Mercedes-Benz W116 280S (The restoration/hobby/project car)
~Chris~
My Diecast Collection!
Old 04-29-2005, 04:56 PM
Samurai75007 Samurai75007 is offline
MMmm Looking good.
One thing, are you still going to have the two cross bar's?
Old 04-29-2005, 05:00 PM
ImolaEK's Avatar
ImolaEK ImolaEK is offline
Re: Re: LEAN MEAN - 360 Challenge Stradale Conversion
Wow, Perfect model in progress
-Joeham-
無限 MUGEN POWER
Email:
[email protected]
MYSPACE
www.myspace.com/joeham
Old 04-29-2005, 05:15 PM
robrex's Avatar
robrex robrex is offline
Just beautiful! Amazing thread again!
Rob
Old 04-29-2005, 05:27 PM
2.2 Straight six's Avatar
2.2 Straight six 2.2 Straight six is offline
That thing got a Hemi?
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
your skills are just amazing, absolutely fabulous, is there anywhere you can buy that mesh on-line ? i have a feeling it woulbe be useful. anyway your car is just outstanding the shine is brilliant and the work you've put in just amazes me, you have made a challenge more real than the real one ! (ok, so it sounded good in my head.....)
Old 04-29-2005, 05:35 PM
p9o1r1sche's Avatar
p9o1r1sche p9o1r1sche is offline
Registered User
Very nice detailing, Alex. Will this one get any leather in the interior? I'm not sure if the real ones have it.
Old 04-29-2005, 06:05 PM
BVC500 BVC500 is offline
Alex,
Did you do anything to prep the resin front bumper and side skirts? I applied Tamiya gray primer to mine and my fingernails were able to scratch the paint off!
Closed Thread
