Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-29-2005, 02:12 PM
Black97GST Black97GST is offline
HELP PLEASE! clutch problem!
ok today i was comming home and i was getting ready to pull into the garage. so i shifted from nuetral to first started moving (about 6 inches) then i feel something in my foot through the pedal like come loose or pop off or something. so i try to take it out of gear and then put it back in and try, but still didnt work. the clutch pedal pushes in REAL easy now. but it doesnt stay down when i push it in it still comes back up like regular. is this a linkage problem??? how easy is it to fix? or how do u do it??? any ideas?
Old 04-29-2005, 09:21 PM
Re: HELP PLEASE! clutch problem!
does anyone know??? please! i have to fix it tomorrow!
Old 04-29-2005, 09:37 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
check the fluid in your master cylinder resirvor. then check all your clutch fluid lines.
95 Talon TSI AWD
97 Eclipse GST
Old 04-29-2005, 11:18 PM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Re: HELP PLEASE! clutch problem!
I don't think that the master cylinder fluid level has any thing to do with it because he said that the clutch pedal doesn't stay on the floor it comes back up. If you can't shift into any gear then I'm thinking that possibly the slave cylinder push rod end that pushes into the throughout bearing might have popped out of place take a look under the car at the slave cylinder and check to see if the rod is at an angle or off to the side (not pushing on anything). If this is what is wrong then try to pop back into place but that may not work so just loosen the bolts that holds the slave cylinder in place and then pop back into place, if that's the problem then it should take only but a few minutes to fix.
I don't know if you know what the slave cylinder is, well it's kind of like the master cylinder but when you push the clutch in it presses hydrolic fluid into the line down to the slave cylinder which pushes fluid into a rod that pushes into the throughout bearing arm. That's it in a nut shell, if that is not your problem keep looking around for the answer, hopefully it's something that easy to fix. Good luck
Old 04-30-2005, 10:24 AM
yeah i know what the slave cylinder is. i replaced it about a year ago. ill go check that now! thanks. ill let you know if thats it
Old 04-30-2005, 10:57 AM
i checked, and thats not it unfortunantly, any one else have any ideas?
Old 04-30-2005, 11:01 AM
CBURKE's Avatar
CBURKE CBURKE is offline
I just had the same thing happen to me. i replaced the master and it still don't work, so next it the slave. Good luck on that.
98 MITSU GST, 1990 TURBO MOTOR
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-30-2005, 11:14 AM
yeah but i just replaced the slave not even a year ago, so i dont think its that.
Old 04-30-2005, 12:02 PM
CBURKE's Avatar
Then It Could Be The Master.
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-30-2005, 12:12 PM
but would it just go out like that w/ out any signs? the master is full of fluid
Old 04-30-2005, 12:13 PM
so no one thinks it the clutch linkage?
Old 04-30-2005, 01:09 PM
i think going to buy a master cylinder and hopefully that fixes it. but if you have any other ideas i am open for them. thanks.
Old 04-30-2005, 02:13 PM
CBURKE's Avatar
What yr is you car? If you have a hyd clutch then there is no clutch linkage, It's fluid.
98 ACURA INTEGRA LS
88 HONDA CIVIC HB
97 HONDA CBR 600
91 HONDA CRX DX
89 JEEP
Old 04-30-2005, 03:27 PM
97 lol o yeah im a dumb ass
Old 04-30-2005, 05:14 PM
even if your brakes work fine, it could still be the master cylinder?
Closed Thread
