Go Back   Automotive Forums Car Chat > GMC > Sonoma | S-15
Old 04-29-2005, 02:56 PM
dtl379 dtl379 is offline
Question what else for my engine?
I have a 4.3 X, and have tried everything. I have gotten wrong info on many things, and just want my engine to stop missing. We have done plugs, wires, cap, rotor, PCV, ignition coil, fuel filter, camshaft position sensor, O2 sensors, checked EGR, cleaned throttle body and plate, run injector cleaners, tried air filters, and checked all electrical connections. When we took off the throttle body, there was gas in the intake and on the throttle plate, along with alot of carbon. Everything started after a tune up, and we have checked and rechecked all the work. Nothing is crossed, and we have tried different brands of everything. At one point, the service light was on for a cam position sensor circut malfunction, and a hard misfire. But the truck ran wonderful and never missed a beat, and was running rich. We are at a loss, the spider lines look good, no cracks. If it is warm and dry outside, it runs great. But bring on a cold rain, and bam. Anyone have any ideas. Without a service code, we are at a loss. Any help would be appreciated.
Old 04-29-2005, 03:37 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: what else for my engine?
You have a fuel leak, there should be no fuel in the intake, only a nice layer of black carbon. Check to see if there is gas in your oil. If there is, you shouldn't drive it until the injection is fixed or you could damage the engine.
Old 04-30-2005, 12:53 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
MAF sensor.
Remove, clean the sensor filiment wires with TB cleaner and a toothbrush gentlely and rinse with TB cleaner after to remove the black gunk on the sensor filaments.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 05-02-2005, 10:07 AM
Thank you both. There is no gas in the oil, so I guess that is good. We will check the lines, and injectors. MAF sensor is clean, was one of first I checked. Thank you though. If none of this works, know anyone who would like a 4.3 with a 10 guage slug imbedded in it?
And, really quick, does anyone out there know where I can get different injectors that would fit my setup. If I have to replace them, I don't want to put in ones with the poppet valve. This is not a project I want to under go every 2 years.
Old 05-02-2005, 11:36 AM
blazee's Avatar
Problem?
You're welcome.
Due to the fuel puddles in the intake, the injection is the most likely culprit. GM does have an updated MFI to replace the CSFI. The MFI does away with the poppit valves. I have a service bulletin from GM that I can email to you, if you would like.
Another to check would be the firing order. You said," nothing is crossed".....you do know that 1 and 3 are suppose to be crossed...right? It is a common mistake for people to connect the wires to the cap:
6 5
4 3
2 1
They should be:
6 5
4 1
2 3
Old 05-03-2005, 10:59 AM
Blazee, please e-mail me the service bulletin. If a dealer has the parts, that would be helpful. Also, I want to try and get the New York State involved, as well as any other states possible. This just is not fair. People everywhere are failing inspections because of the federal clean air act. Also I do have the wires correct. I was a little confused at first when I looked at the firing order for the engine, and then the cap. kinda strange-but what do you want. Thank You for your help. Danielle @dtl379
Do you know how I can get a hold of the truck's Canadian history?
Old 05-03-2005, 11:51 AM
blazee's Avatar
Problem?
I need your email address to send you the service bulletin.
Luckily in Florida we don't have inspections. Seems like most of the people that come to these forums needing help are ones that just failed their inspection.
I don't know how to get the Canadian history.
Old 05-03-2005, 04:10 PM
BlazerLT's Avatar
AF -Advisor
Re: Re: what else for my engine?
Make sure 1 & 3 are setup properly.
It is often overlooked.
Old 05-04-2005, 10:11 AM
thank you everyone. I just wanted to know if anyone knows how to get the canadian history. I found out that the truck was built in Jersey, shipped to canada, then at some point sold back into the US. We were never informed of this, and GM of Canada said that all vehicles sold into their market has the odometer in Kilometers. My truck now reads in miles, so something was either swiched out or turned. I want to confirm the mileage, but GM doesn't have any record of the truck being brought back to the US. They said they didn't turn the odometer-so who did? GM also with not give me any of the trucks history. I dont want names of past owners, just the trucks vehicle history.
Old 05-04-2005, 05:16 PM
BlazerLT's Avatar
AF -Advisor
Get a carfax done on the VIN number.
Old 05-05-2005, 02:47 PM
Does that include Canada's vehicle history? I dont want to spend 25-50 bucks on just the US history.
Old 05-05-2005, 05:44 PM
BlazerLT's Avatar
AF -Advisor
Yes, it should. Carfax shows both countries records.
Old 05-16-2005, 10:13 AM
We took off the intake plenum and found that we have oil in the intake, along with the carbon layer. We also had a small amount of gas. All the spyder lines look fine, the metering body and gaskets look fine, although they have a tim layer of oil on them. The poppets are spotless on the ends, but have some build up around the bottom of the connection that sits in the engine.
We are being told that the oil is there due to "Back Blow" and to try an engine flush to clean out the ports. I wanted to check into this first, and ask if anyone can suggest a good engine flush. I dont want to blow out any seals and gaskets, or ruin any sensors. I have heard mix reviews over doing engine flushes. I also wanted to know if back blow can cause the misfire condition we have been having. Any suggestions?
"I'm finding the idea of a ten guage slug quite tempting right now!"
Old 05-16-2005, 01:05 PM
BlazerLT's Avatar
AF -Advisor
The carbon and oil is from the PCV sustem. Completely normal.
Just make sure you don't overfill your oil.
Old 05-17-2005, 02:38 PM
Could this cause or agravate a misfire condition? Could it cause sensors in the throttle body to malfunction? Just wondering, and still tring to track down the misfire. THank you.
