Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 04-29-2005, 09:03 AM
drumsnbass2004 drumsnbass2004 is offline
Wont start
I have a 2002 Impala The security light came on while i was driving.. so i didnt drive it much anymore... Now the car wont start at all.. The dash lights come on but nothing else.. no dome light, not power windows/locks, no headlights... Any idea? i suspect its the passlock, but is there any way to get it started so i dont have to have it towed? i've waited probably a half hour and still no luck... HELP!!
Old 04-29-2005, 09:54 PM
bermis519 bermis519 is offline
Send a message via AIM to bermis519 Send a message via MSN to bermis519 Send a message via Yahoo to bermis519
Sounds to me, might be your body control module BCM that has either gone bad, lost power, or if they can, reprogram it. If i remember right, i think they are only like 55 bucks. But don't quote me....i've had mine replaced, but after everyhing else thats been replace i can't remember how much it was....same problem as you where having...
mike
Old 04-30-2005, 07:19 AM
Re: Wont start
Well...my car started up fine yesterday morning so it was driven to the mechanic... I got my car back last night... $400+ for repairs. It was some module.. dont remember exactly which one...
Old 04-30-2005, 07:20 AM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Wont start
It is probably not the BCM, but rather the BCM connector. Chevy has had problems with them for 2000 - 2005 Impalas and Monte Carlos. This is a routine problem. The wire terminals may be loose or damaged. Start with BCM connector C1 (the pink one) check terminal B9 (white wire) and B12 (black wire). Then BCM connector C2 (the grey one) check terminal A3 (yellow wire). Check all the wires, but pay close attention to the ones mentioned.
**Edit** Posted too late.
If the mechanic only replaced the BCM, your problem may return. If the problem returns you should check the terminals, I just mentioned.
Old 04-30-2005, 08:42 AM
anolizor anolizor is offline
Re: Re: Wont start
This is under the dash? I can't find much at all on the location of the bcm and the terminals. (no pictures either)
Old 04-30-2005, 09:33 AM
Re: Wont start
Thanks for the responses.. I'll check that if the problem comes back...
