Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 04-29-2005, 08:12 AM
sir_fairy sir_fairy is offline
disabling the security system
i have a 92 bonnie. anyone know a way i could kill the security system, without killing the car? it keeps causing--in various ways--my car to not start. like i said, it's a 92; i'm not too worried about anyone stealing it.
Old 05-05-2005, 04:20 PM
randman1's Avatar
randman1 randman1 is offline
Re: disabling the security system
Are you referring to the VATS? If so, a resistor of equal value to the key can be connected to the VATS wires below the column. This would only help if the problem is at the ignition switch and not elsewhere down the line.
You might just try cleaning both the key and the ignition cylinder with rubbing alcohol before fiddling around with the wiring though.
Old 07-26-2005, 02:21 PM
bslewis bslewis is offline
Re: Re: disabling the security system
GOTO http://www.likeabigdog.com/column/vats.htm
THEIR SOPLUTION WORKS IF YOUR KEY OR SWITCH IS MESSED UP/ NOT THE VATS MODULE. CHEAP ALSO
