Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 04-29-2005, 01:17 AM
toyotasr5p toyotasr5p is offline
4x4 indicator light
My truck is a 1991 v6 4x4 automatic transmission. When I switch to 4x4, the idicator light under the tach, starts blinking very rapidly. I tested the drivetrain and the 4x4 IS engaged, 4 wheels have power. Somebody told me it could be a vacuum leak, or some sensor on the 4wd system. Any ideas???? thanks
Old 06-11-2005, 10:59 AM
Tim81ta Tim81ta is offline
Send a message via ICQ to Tim81ta Send a message via AIM to Tim81ta Send a message via MSN to Tim81ta Send a message via Yahoo to Tim81ta
Check the connections to the light itself. They could be a problem in the wiring, possible a cross short.
Tim81TA
Old 06-13-2005, 11:27 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Check your owners manual. Blinking should be indicating a problem, quite possibly a vac leak if you have the ADD front axle.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
