Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-28-2005, 08:21 PM
pissedriteoff pissedriteoff is offline
Overdrive
My Idea Of Overdrive Is That When You Are Highway Driving You Can Hit The Button And The Revs Should Drop. Is There A General Speed You Can Do This. Mine When Going About 100km When You Hit O/d The Revs Go Up. Also Will Changing To The Atf+4 Help With Shifting Problems From 2nd To 3rd When -20 Degrees Out. I Just Bought The Truck 96 Ram 1500/318 And Have Not Changed Or Do Not Know When The Last Change Of Fluid Was. It Looks Clean And There Is No Smell.
Old 04-28-2005, 08:46 PM
troy1 troy1 is offline
AF -Advisor
Re: Overdrive
your rpms should never go up somethings not right od is slipping or the TC not locking up I would have it checked. how much does it change by the way. The shifting from 2-3 when cold is a issue with the inner sealing ring on the direct clutch. the grove for the seal is cut to deep so the seal over time shrinks and loses its sealing ability. this problem gets better when the transmission warms up most of the time.
Old 04-28-2005, 08:53 PM
Changes About 500rpm, Minimal But Noticeable...what Is Tc?
Old 04-28-2005, 08:55 PM
AF -Advisor
Re: Overdrive
Torque converter clutch sounds like the problem to me with only a 500 rpm change. TC is torque converter. how late of a shift is the 2-3?
Old 04-28-2005, 09:17 PM
Shifts Are Normal 25/45/75km
Old 04-28-2005, 11:23 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: Overdrive
ATF+3 only. DO NOT use anything else.
My Mopars
Old 04-29-2005, 07:29 AM
dcram dcram is offline
Well if your truck is in o/d, when you press the overdrive button it takes it out of top gear (5th) into 4th gear and therefore your revs will go up... this is normal. If however o/d is off and you press the button the truck should go into o/d (granted your moving fast enough) and the rpms will then drop.
Old 04-29-2005, 06:40 PM
BleedDodge's Avatar
Re: Overdrive
That's false. Pushing the button will take it out of overdrive and into third gear. His transmission is an automatic four speed eh.
My Mopars
Old 04-30-2005, 06:35 AM
Thanx all...I took a closer look at the button and figured out is says O/D OFF.......Spoke to my mechanic (brother lol) and he confirmed. It is a 3 speed with Automatic O/D and when you hit the button the O/D comes off therfore increasing the revs
Old 04-30-2005, 06:41 AM
Bleeddodge: I was reading a service bullitin in here about the ATF+4. Dodge apparently has improved the fluid. They recommmend the switch ,even as a top up procedure...Dont ask me where but it was,but it was in one of the threads in here....I have read alot of stuff since becoming a member and I gotta tell ya this site is awesome. I picked up the truck for 2000 CDN and I love it. If I can find all the fixes for stuff in here then a whole lot of cash can be saved. PS Thanx for ur input
Old 04-30-2005, 10:14 AM
BleedDodge's Avatar
Re: Overdrive
Go here and read about halfway down where it says "What type of fluid to use?"
http://www.allpar.com/fix/trans.html
My Mopars
Old 05-03-2005, 09:19 PM
bleeddodge...found out where i saw the atf+4 for the tranny.
check out the tsb's and look up tsb21-004-04
Old 05-03-2005, 10:36 PM
BleedDodge's Avatar
Re: Overdrive
Your truck is a '96 right?
My Mopars
Old 05-04-2005, 11:35 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Overdrive
Hey Bleed, actually ATF+4 is what should be used for 94-present Ram pickups, read this TSB
NUMBER: 21-006-01
GROUP: Transmission
DATE: Jun. 29, 2001
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 21-16-99, DATED OCTOBER 22, 1999, WHICH SHOULD BE REMOVED FROM YOUR FILES AND NOTED IN THE 1999 TECHNICAL SERVICE BULLETIN MANUAL (PUBLICATION NO. 81-699-00004). THIS IS A COMPLETE REVISION AND NO ASTERISKS HAVE BEEN ADDED TO HIGHLIGHT REVISIONS.
SUBJECT:
Automatic Transmission Fluid Usage ATF+4 (Type 9602)
MODELS:
1989 - 1995 (AA) Spirit/Acclaim/Lebaron Sedan
1989 - 2002 (AB) Ram Van/Wagon
1989 - 1993 (AC) Dynasty/New Yorker/New Yorker Salon
1989 - 1993 (AD) Ram Truck
1989 - 1994 (AG) Daytona
1989 (AH) Lancer/Lebaron GTS
1989 - 1995 (AJ) Lebaron Coupe/Lebaron Convertible
1989 - 1990 (AK) Aries/Reliant
1989 - 1990 (AL) Horizon/Omni
1989 (AM) Diplomat/Gran Fury/New Yorker Fifth Avenue
1989 - 2002 (AN) Dakota
1989 - 1994 (AP) Shadow/Sundance
1990 - 1991 (AQ) Maserati
1990 - 1993 (AY) Imperial/New Yorker Fifth Avenue
1994 - 2002 (BR/BE) Ram Truck
1998 - 2002 (DN) Durango
2002 (DR) Ram Truck
1995 - 2000 (FJ) Sebring/Avenger/Talon
2000 (GS) Chrysler Voyager (International Market)
1995 - 2000 (JA) Cirrus/Stratus/Breeze
2001 - 2002 (JR) Sebring Sedan & Convertible/Stratus Sedan
1996 - 2000 (JX) Sebring Convertible
2002 (KJ) Liberty
1993 - 2002 (LH) Concorde/Intrepid/Vision/LHS/New
Yorker/300M
1989 - 1992 (MJ) Commanche
2000 (NS) Town & Country/Caravan/Voyager
1995 - 2002 (PL) Neon
2002 (PG) PT Cruiser (International Markets)
2001 - 2002 (PT) PT Cruiser
1997 - 2002 (PR) Prowler
2001 - 2002 (RG) Chrysler Voyager (International Markets)
2001 - 2002 (RS) Town & Country/Caravan/Voyager
1997 - 2002 (TJ) Wrangler
2001 - 2002 (WG) Grand Cherokee (International Markets)
1999 - 2002 (WJ) Grand Cherokee
1989 - 1995 (YJ) Wrangler
1996 - 1998 (ZG) Grand Cherokee (International Markets)
1993 - 1998 (ZJ) Grand Cherokee/Grand Wagoneer
NOTE :THIS BULLETIN APPLIES TO ALL VEHICLES EQUIPPED WITH CHRYSLER AUTOMATIC TRANSMISSIONS EXCEPT 1999 AND EARLIER MINIVANS.
DISCUSSION:
A new transmission fluid (ATF+4(R) - Type 9602) has been developed and is being used as factory fill for all vehicles with Chrysler automatic transmissions. Until now, vehicles originally filled with ATF+2 or ATF+3 were to be serviced with ATF+3. Effective immediately, it is recommended that all vehicles with Chrysler automatic transmissions except for 1999 and earlier minivans be serviced with ATF+4(R). ATF+3 should continue to be used for 1999 and earlier minivans because of the potential for torque converter shudder during break in. For all other applications the ATF+4(R) fluid offers significant benefits as outlined below.
NOTE :ATF+4(R) MUST ALWAYS BE USED IN VEHICLES THAT WERE ORIGINALLY FILLED WITH ATF+4(R).
NOTE :SERVICE INTERVALS DO NOT CHANGE. THE SERVICE INTERVAL CURRENTLY IN EFFECT FOR A GIVEN VEHICLE SHOULD CONTINUE TO BE FOLLOWED.
NOTE :ATF+4(R) IS COMPATIBLE WITH ATF+3 AND CAN BE USED TO TOP OFF VEHICLES THAT CURRENTLY HAVE ATF+2 OR ATF+3. DO NOT USE ATF+2 OR ATF+3 TO TOP OFF VEHICLES THAT HAVE ATF+4(R) FLUID.
BENEFITS
^ Better anti-wear properties
^ Improved rust/corrosion prevention
^ Controls oxidation
^ Eliminates deposits
^ Controls friction
^ Retains anti-foaming properties
^ Superior properties for low temperature operation
FLUID COLOR
Mopar ATF+4(R) is a World Class Fluid having exceptional durability. However, the red dye used in ATF+4°R is not permanent; as the fluid ages it may become darker or appear brown in color. ATF+4(R) also has a unique odor that may change with age. With ATF+4(R) fluid, color and odor are no longer indicators of fluid condition and do not support a fluid change.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 05-05-2005, 08:09 PM
BleedDodge's Avatar
Re: Overdrive
I'll remember that. Thanks.
My Mopars
