Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Audio and Videos
Old 04-28-2005, 06:52 PM
a17aron a17aron is offline
Send a message via AIM to a17aron Send a message via Yahoo to a17aron
Lightbulb Radio with factory amp trying to replace
i am trying to replace the radio in my 98 eclipse that has a factory installed amp, and it will not work i have replaced tons of radios before but have never replaced one that has a factory amp does anyone know how to do this?
Old 04-30-2005, 02:33 PM
nova1313's Avatar
nova1313 nova1313 is offline
Re: Radio with factory amp trying to replace
there is a kit availiable I know for the premium sound options that will allow you to use a non factory head unit with the amp/speakers
That site did have them before but seems to be dead to me now. Try it though. It was about half way down the page.
http://www.installer.com/cars/mitsubishi.html
Once you have the adapter it seems as if it's just plug it in and go. I was thinking of doing this myself but didn't get to it yet. No cash bummer....
08 Kawasaki Ninja 250R - Plasma Candy Blue
07 Toyota Rav4 - Ltd Ed. 6 Cyl AWD
97 Mitsu Eclipse Spyder GS-T 5 Speed
Old 05-10-2005, 09:05 AM
bighauns's Avatar
bighauns bighauns is offline
Send a message via MSN to bighauns
For an 80 dollar bypass harness I would say just get rid of the stock amp and put that towards a new speaker amp when you buy your new deck. That is a waste of money.
"You can have everything in life you want if you will just help enough other people get what they want."
Old 05-10-2005, 09:16 AM
nova1313's Avatar
Re: Re: Radio with factory amp trying to replace
I'm talking about the one all the way down
MITAH
1990-2002 Mitsubishi built cars with Infinity Systems
Direct plug in adapter to replace factory head unit or amp.
one of our most popular parts of all time.
24.95
That one doesn't seem to bad. But yeah if it's the 80 dollar one you really need then I'd say go for the new amp / speakers.. If you do that whatever you buy do not buy dual products.
Old 05-11-2005, 08:36 AM
bighauns's Avatar
Oh, I didnt see that one. Well, even still that is additional cash over top of the regual harness for a new head unit. I would say that is still isnt worth the trouble to go through it. That is just my opinion. An aftermarket amp would do wonders compared to that one.
Just my two cents.
Old 05-28-2005, 09:51 AM
BoNkA10 BoNkA10 is offline
Send a message via AIM to BoNkA10
What are the specs on that infinity amp? The model # on mine is MR158402, but can't find anything on google. I'm probably just going to have it ripped out and replaced with my own amp anyways.
1998 Eclipse GS
Old 05-31-2005, 10:58 PM
bighauns's Avatar
That is the way to go, dont even bother with the stock thing...just get a new one.
Old 06-17-2005, 09:01 AM
fiberglasscivic's Avatar
fiberglasscivic fiberglasscivic is offline
Send a message via AIM to fiberglasscivic Send a message via Yahoo to fiberglasscivic
It's a lot easier than using a wiring harness to bypass the amp. Use a line level converter to convert the output on your stereo work with your amplifier. They run about $15-$20 for one that will convert 4 channels. You run it inline with the speaker wires and it makes your stereo compatible with the factory amp. It's really easy.
AF COMMUNITY GUIDELINES
Old 02-05-2008, 03:01 PM
tclarkmd's Avatar
tclarkmd tclarkmd is offline
Here's what I've learned about the factory Inifinity system:
Head Unit: attaches to amp via black 6-pin DIN cable (4 channels, pwr, gnd). MITAH and MITSRCVR adapters will change this 6-pin DIN cable into four (front L/R and rear L/R) RCA plugs and a "turn on lead" to go into after market amps. You'll likely also need LVT (low volt trigger) for other amps to signal power on.
Amp: Inputs: 6-pin DIN (4 channels, power and grnd)
Outputs: unknown specs, likely 100W/channel, attaches to speakers via white harness.
THE STOCK INFINITY AMP HAS HI PASS FILTERS FOR FRONT DASH TWEETERS AND LOW PASS FILTERS FOR FRONT DOORS BUILT IN!
Therefore, front door speakers are only mid/bass, with no highs. Keep your front dash tweeters if you use the stock amp and want highs up front. New tweeters (if yours are spent like mine) can be retrofit into covers if they are small (neo tweeters): http://www.dsmtuners.com/forums/arti...-speakers.html
You can use wiring harness/adapter 70-7001 to create free wire ends for your speaker connections for an after market amp hookup. 70-7001 just plugs into your stock speaker wires' original white amp harness. You can do without the 70-7001 by just cutting the wires off the original amp harness/plug. <Do not confuse with 71-7001 (which creates new speaker wire hookups from stock amp)>
note: MITAH from installer.com also includes speaker wiring harness/adapter (70-7001). Other sellers (such as hifisoundconnection.com) do not inlcude this adapter in their MITAH adapter (MITSRCVR only)
Hope this helps somebody. It took me a while to piece it all together.
Old 02-05-2008, 03:15 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
This thread is almost 2 years old. Please dont bring back old theads like this.
Welcome to AF
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 04-13-2008, 08:54 PM
BasilRathbone BasilRathbone is offline
Thank you FOR bringing back an "OLD" thread like this. This is just the kind of information I've been looking for! You say there are four audio pins plus power and ground? Are you sure the unit doesn't get power from the 18pin plugin cable? I was under the impression that the "power" pin was actually an "LVT" pin. I sure wish there was a schematic available for this puppy.
Old 04-16-2009, 10:48 PM
sglapa sglapa is offline
I second the comment from BasilRathbone. The Infinity receiver in my 1998 Eclipse just gave up the ghost, and this is priceless info to have!
thanks
Steven
