Old 04-28-2005, 05:47 PM
1g90gsx's Avatar
1g90gsx 1g90gsx is offline
Scm 50 Trim I Got Today:SMALL 16G FS!
well i got my precision 50 trim off ebay last week from an s2000 revhard kit with 500 miles for $420.00 shipped.i also got the bullseye turbine housing off ebay wich i have not received in three weeks so, im pretty much screwed out of $125.00 i payed for it and im highly pissed off.i have to cut off the elbow but i like fab work anyway so i guess ill have to buy a new turbine housing to bolt up.
well im going to be selling my small 16g thats from a fuso truck.i used the compressor housing and center section and bolted it up to my turbine housing since its a td05 wheel it fits right.it has a little shaft play but not much and its tapped for an a-n fitting also.return line is the same and also youll need an external wastegate setup. ill take $150.00 shipped if anyone is interested let me know!
thanks!
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
INNOVATIVE DUEL BB TURBO
TURBONETICS MANIFOLD
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AEROMOTIVE STARLITE HOSE
AUTOMETER
ROTA CIRCUT 8"S
Old 04-28-2005, 07:20 PM
joemathews's Avatar
joemathews joemathews is offline
Re: Scm 50 Trim I Got Today!
Doesn't look like a 16g to me, but it's your turbo. Congrats on the new purchase--I hope everything goes smoothly! I'd use new turbo bolts if I were you
1996 Eagle Talon
Old 04-28-2005, 07:29 PM
1g90gsx's Avatar
thanks,but its hard to beleive that its a small 16g but thats the size of the wheel when measured with the micrometer.it just has a larger compressor housing than the other td05"s.im not using the turbine housing in the pic because i won one on ebay for a direct bolt on for the precision turbo and got screwed!
1990 MIRAGE HB
4G SWAP
FMIC
ACT 2100
TIAL BOV
TIAL WASTEGATE
FIC 650"s
SX AFR
MAFT
255 PUMP
WISECO 8:51
EAGLE RODS
DELTA 272 CAMS
SETRAB OIL COOLER
AUTOMETER
ROTA CIRCUT 8"S
