Old 04-28-2005, 04:57 PM
awdpower awdpower is offline
Send a message via ICQ to awdpower Send a message via AIM to awdpower Send a message via Yahoo to awdpower
need help more sensor problems
hey well i fixed the 02 sensor problem but now there is 2 more besides the closed loop fuel control insufficient coolant temp sensor. One of them is the idle control system, and the other one is IAT sensor circuit. can anybody tell me where they go so i can change them.
Old 04-29-2005, 06:55 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: need help more sensor problems
IAT is on the lower part of the throttle body just below the TB elbow. It has a brown connect with 6 pins or so. Held on with 2 8mm bolts. Those two codes are probably both for the ISC. It may not be the ISC though, even if the ECU thinks that is it. Check www.vfaq.com and www.crebotech.com for more info and some tests you can do to verify the ISCs functionality. Things like intake leaks, bad FIAVs, or bollixed BISS setting can force the ISC to its maximum travel, effectively rendering it useless. There is no feedback loop from the ISC (open loop stepper motor) to let the ECU know its maxed out. The ECU just keeps trying to move it further, and nothing changes with idle speed. Etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-29-2005, 10:10 AM
Re: Re: need help more sensor problems
u think im losing speed from those three sensors. if i am how much?
Old 04-29-2005, 12:10 PM
AF - Advisor
They have no effect on power output.
Kevin Jewer
Old 04-29-2005, 04:35 PM
would i lose speed if i have the check engine light and says fuel trim (bank 1) because i restarted the ecu and this is what i got.
Old 04-30-2005, 09:41 AM
AF - Advisor
It will affect fuel economy and emmissions, but trims are not used at WOT. So that wont affect power output either once it goes open loop.
Kevin Jewer
Old 04-30-2005, 10:24 AM
do you know what that is. fuel trim (bank 1) is it also a sensor or what. how can i fix that problem. sorry for all the questions.
Old 05-01-2005, 05:23 AM
AF - Advisor
That shoud have been a code from the bas O2 sensor. Did you clear the codes after replacing the sensor? They wont go away on their own. Reset them with a logger or scan tool, and see which ones come back. Continue doing this until you have fixed them all.
Kevin Jewer
Old 05-02-2005, 10:42 AM
i already did and that was the one that came up after erasing them and driving for a while. so far thats the only one that came up after puting on the new o2 sensor and restarting them
