Old 04-28-2005, 03:37 PM
tcfco2005 tcfco2005 is offline
open loop? close loop?
i hear and read about this alot but i dont know what it is refering to. can someone fill me in...thanks
1991 RS
305 T.B.I.
700-R4
Old 04-28-2005, 04:12 PM
Hypsi87's Avatar
Hypsi87 Hypsi87 is offline
I got your v-8 swingin!!!
Send a message via AIM to Hypsi87
when your computer detects a cold coolant, and a cold air temps, it goes into what is called open loop.
Open loop refers to the o2 sensor circuit. The computer ignores the o2 circuit and "opens" the circut and injects fuel based on a cold engine fuel map. When the coolant temp gets warm enough, the computer then "closes" the o2 circuit sensor and uses the sensor to more accuratly deliver fuel.
When you are in open loop, o2 sensor is not used and you are injecting rich ammounts of fuel.
in closed loop, your 02 sensor is read and your fuel dilevry is more accuratly monitored and controled.
Grand National. Going fast with class.
Voted FASTEST street car on AF.
Here is the proof!!!
1987 Buick Grand National.
Back in action!!!!
1999 Ford F-250
Tow rig from hell 598 Ft-lbs.
ASE Certified in...
Mobile AC
On Highway medium duty diesel engines.
Off highwayy medium duty diesel engines.
On highway trucks.
Working on the eletronics certification
Member of
A.A.N.B.C- Afer against non boosted crews #2
Old 04-28-2005, 04:43 PM
Re: open loop? close loop?
thanks man ive been wondering that for a while now
1991 RS
305 T.B.I.
700-R4
Old 04-29-2005, 03:21 AM
supervisor1886's Avatar
supervisor1886 supervisor1886 is offline
Banned
I have aquestion here. Would that be possible to run open loop even when the engine is hot without having any codes on the computer. I suspect this, because my 2.8MFI gas mileage can be compared only to a 5.7 tpi one.? Funny? The car runs fine, no signs of rich exh., new pump, new fuel filter.
Old 04-29-2005, 07:52 AM
Hypsi87's Avatar
Re: Re: open loop? close loop?
yea if your PROM has the programming in it.
My PROM program is set to go into open loop at idle because if my torque converter. With my loose converter (3300) it helps it with idling.
Back in action!!!!
1999 Ford F-250
ASE Certified in...
Mobile AC
On highway trucks.
Member of
