Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 04-28-2005, 02:25 PM
TbagginTbird93 TbagginTbird93 is offline
Lug pattern question
I was wanting to order some 20 inch rims and tires for my car, the tires are Pirelli Pzero 245/35/20.. would this be a problem for fitting in the wheel wells? the rims im looking at range from 20" x 8.5 " to 20" x 9.5"
also the lug pattern for a 1993 Tbird LX anyone know it?
Currently rod out of 1993 Tbird 3.8L... New motor on the way from http://www.groomsengines.com in Nashville TN *
Old 04-28-2005, 05:51 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
Re: Lug pattern question
the lug pattern is 5x4.25. Dont know if they would fit.
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 04-28-2005, 08:35 PM
8ate8 8ate8 is offline
Send a message via ICQ to 8ate8 Send a message via AIM to 8ate8
there's a small choice of rims available for the tbird. you'll most likely need some custom spacers if you do find some 20" rims in our bolt pattern.
1996 Thunderbird LX 3.8L
1993 Thunderbird SC 3.8L
2000 Cherokee Sport 4.0L
2005 Tacoma X-Runner
Jersey Rice
NJ Thunderbird & Cougar Club
Old 04-29-2005, 01:50 AM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Sure, those tires will fit in the wheel wells.
Whether the wheels and/or tires will rub is dependent upon the backspacing / offset of the wheels.
Old 04-29-2005, 02:56 PM
Hey JR. what size and brand tires and wheels u have on your bird? im looking at a design very similar to those on your car...
Old 04-29-2005, 06:02 PM
Re: Re: Lug pattern question
Front tires - 245/45/18 Nitto555's
Rear tires - 255/45/18 Nitto555's
Wheels are Polo-776, 18"x7.5".
Old 04-30-2005, 01:46 PM
and those would fit with no problems on a 93?
Old 04-30-2005, 09:24 PM
My tire/wheel combo will fit on any stock '93-'97 Thunderbird/Cougar.
Ford had a different spindle design for the '89-'92s.
Old 05-01-2005, 06:23 PM
the car was manufactured in 9-92.. so would the rims still work or?
