Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 04-28-2005, 12:56 PM
ranchen's Avatar
ranchen ranchen is offline
ABS on TP -92
How can I disconnect the hole ABS-system?
I´m not intressted to pay lots of money (25% of the value of the car).
So now I want to disconnect the ABS-sytem. How do I do that?
Old 04-29-2005, 07:38 AM
LMP's Avatar
LMP LMP is offline
Re: ABS on TP -92
In my '93, I pulled the fuse marked ABS
www.avigex.ca/xport/fusepanel38.jpg
or if you have a 3.1
www.avigex.ca/xport/fusepanel31.jpg
from the glove box fuse panel very early specially for winter time operation where ABS was just a pain.
SInce then, ABS has quit totally anyway and the hell with it.
SO...pull the fuse out and all is fine.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 04-29-2005, 08:36 AM
ranchen's Avatar
Re: Re: ABS on TP -92
But the ABS warning lamp is still glowing...?
(I have a 3.8 from -92
Old 04-29-2005, 11:57 AM
LMP's Avatar
LMP LMP is offline
Re: ABS on TP -92
Oh......of course.......mine too......., but I'm so used to it I do not even notice it anymore.
The lamp is energized through the ABS Lamp Driver MOdule, located behind the parking brake cable bracket. This is a 6 connector plug that looks like this:
www.avigex.ca/xport/absplug.jpg
..may be after all that time I could take a look myself and kill that light...lol
But there is another 3 amp fuse in the ABS enable relay box, just near and below the brake booster. I did not check if removing this one too would disable the antilock warning . Probably this electronic contact to ground that is part of the electronic brake control module is "on" as default value and is deenergized only when all is in nominal condition.......
