Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-11-2001, 01:03 AM
imorley imorley is offline
Angry rough hot starting
I have a 90 Maxima that has a problem with starting after it has been driven until at operating temp and then shut off for a short while. It starts right up but idles extremely rough. After I drive it for a short distance it will idle fine again.
Does this sound like a leaking injector? How can one diagnose that situation, reading the plugs?
Any suggestions would be appreciated.
Old 07-11-2001, 01:51 PM
DVSNCYNIKL's Avatar
DVSNCYNIKL DVSNCYNIKL is offline
R.I.P. DAD 3/25/11
Send a message via ICQ to DVSNCYNIKL Send a message via AIM to DVSNCYNIKL Send a message via Yahoo to DVSNCYNIKL
It can be a number of things. You just have to narrow it down through the process of elimination. You might need a tune up. You might just need to clean the injectors. Could be the plugs. Could be the timing. Could be water in the fuel lines from condesation. You have to do little things to see if it stops. If not, it could also be your timing needs adjusting. As you can see, many possibilities. If you're doing it yourself, then you have to do these things or you could just take it to a mechanic and he'll find out for you.
Why do banks charge you a "non-sufficient funds fee" on money they already know you don't have?
