Old 04-28-2005, 10:45 AM
jasonpzahn jasonpzahn is offline
steering problem with 97 cavalier
Hi when i make a turn i hear a loud clunking noise and its getting worse, is there some sort of ball joint that connects the steering column with the drive shaft and if that is worn out about how much should it cost me to fix the problem
Old 04-28-2005, 07:08 PM
OverAllComa OverAllComa is offline
Send a message via AIM to OverAllComa
Re: steering problem with 97 cavalier
CV Joints, tie rod ends, other things are just as likely. Go get it looked at if you can't figure it out. Last thing you need is your steering going out on you.
1992 Chevrolet Cavalier Z24 *R.I.P.*
3.1L MPFI (3.1 6cylinder Pushrod 12V)
1997 Chevrolet Cavalier Z24 *R.I.P.*
2.4L "Twin Cam" (2.4 4cylinder DOHC 16V)
2003 Honda Accord EX V6 - The new hotness
Old 05-02-2005, 09:33 AM
nachoman nachoman is offline
I've got the same problem in my 01' Cavalier. You're not alone. There's a technical service bulletin out from GM about this issue. You need to replace your Intermediate Steering Shaft. I paid $77.00 for the dealer to tell me this. Then I subscribed to www.alldatadyi.com and it said the same thing! I bought the part from the dealer for $67.00 and am going to try to do it myself tonight. If not, Pep Boys said they would put it in for $150.00.... hope this helps!
Old 05-02-2005, 09:48 AM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
^^^ Ditto... had mine done aswell. Its the steering shaft.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 05-05-2005, 10:31 PM
014drcavalier 014drcavalier is offline
i dont know if you guys know about this but gm had a recall out on the rack opion bearing on the 95-99 cavys.. i had a 98 and evertime i turned it popped and after they fixed it it stopped popping....
