Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 04-07-2002, 05:07 PM
PFCfutrell PFCfutrell is offline
Send a message via AIM to PFCfutrell Send a message via Yahoo to PFCfutrell
CRX SI vs 3000GT
On my way to SC with a friend for the weekend I came up behind a green 3000GT (not VR4) and pulled up next to it at about 70-75mph. He stepped on it so I dropped to third gear and started pulling on him, I shifted to 4th at bout 90mph. I shifted into 5th at around 120mph and was about 4 or 5 carlengths ahead before I hit the brakes and hauled down to 70-75mph. The 3000GT had aftermarket exhaust, rims, and dark tint, we couldn't tell if it was a base model or an SL but it wasn't a VR4 for sure. Either way it was a pretty good kill i'd say, what are they supposed to run in the 1/4?
1991 CRX SI (black)
15.3 @ 88mph (stock motor)
'90 B18A1 swap
Custom exhaust
*2.25" piping
*two glasspacks (inline)
*polished flash-cut tip
*exits pass. side, front of rear tire.
'95 GSR 15" wheels
195/50/R15 Bridgestone Potenza SO-3's
AE Eng. front crossmember
Susp. Tech. 22mm rear sway bar
Susp. Tech. 1.8" lowering springs
Tokico Illumina 5-way adj. shocks
Powerslot rotors
Metal Master pads
Goodridge steel-braided brake lines
Red painted OEM calipers
Skunk2 short shifter
Skunk2 shift knob
GT Grant steering wheel
Red/black racing seats
Old 04-07-2002, 06:56 PM
mgcatthew mgcatthew is offline
Send a message via AIM to mgcatthew Send a message via Yahoo to mgcatthew
good kill. even better that you had to come up from behind to pass him. 3000gt's are good cars (from my view) we dont see many out here where i live.
scooby-dooby doo!!!!!
Old 04-07-2002, 07:35 PM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
They run in the 16s.
There's no replacement for displacement...No, not even a turbo.
Old 04-07-2002, 10:21 PM
They only run 16's? it's kind of sad that there's that big a gap in performance between the turbo/NA cars but 16's seems so slow for a V6. My car was in the 16's not long ago, 15's now, 14's soon...
1991 CRX SI (black)
'90 B18A1 swap
Custom exhaust
*2.25" piping
'95 GSR 15" wheels
Powerslot rotors
Metal Master pads
Skunk2 shift knob
Old 04-07-2002, 10:25 PM
kidrocket kidrocket is offline
Send a message via AIM to kidrocket
they weigh over 3000 pounds. 16s are about right
Old 04-07-2002, 10:30 PM
A20A1's Avatar
A20A1 A20A1 is offline
Send a message via AIM to A20A1
Damn my 2 gear does 80 - 85 mph @ 7,300 - 7,500 rpm
and my 3rd gear does 120 -125 mph at the same rmp range.
I guess my 4 speed Auto has a different ratio then most 5 speed manual cars.
I might as well drive a 3speed auto since i never get a long enough road to use 4th.
you're right though 16's is a bit slow for a V-6, even more so for a 3000 GT.
-MIKE
"THE REWARD IS IN THE JOURNEY..."
3geez member since: September 11, 2001
Cardomain
89 Accord
95 Corolla
Old 04-07-2002, 11:05 PM
I hit...
30ish in 1st
60 in 2nd
90 in 3rd
120 in 4th
125+ in 5th (my speedo doesn't go over 125 but i've put it WAY into the dash before)
1991 CRX SI (black)
'90 B18A1 swap
Custom exhaust
*2.25" piping
'95 GSR 15" wheels
Powerslot rotors
Metal Master pads
Skunk2 shift knob
Old 04-07-2002, 11:18 PM
PoisonFangs PoisonFangs is offline
Banned
Send a message via AIM to PoisonFangs
Nice kill bro.
Old 04-08-2002, 04:03 PM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Nice kill. There are SL models that pull mid 15s. I wonder if you ran into one of the few base models that they made (No badging of SL or VR4 on it). Those only had a 161hp and were up in the 17s in the 1/4. Either way, it was still a good kill.
Resistance Is Futile (If < 1ohm)
Old 04-08-2002, 04:40 PM
if it were a 17 second car i would have spanked it much worse than i did, i'm guessing it was a mid to high 15 car although it's hard to tell at the speeds we were traveling. My friends Eclipse GST beats a lot of Z28's at the track but would spank them way worse on the highway at speed where wheelspin isn't a problem. He beat a 3000GT VR4 from a rolling start, if he raced one from a stop they would get a major lead on him. I might be picking up some drag radials for pretty cheap pretty soon, hopefully get some sub-2 second 60' times
1991 CRX SI (black)
'90 B18A1 swap
Custom exhaust
*2.25" piping
'95 GSR 15" wheels
Powerslot rotors
Metal Master pads
Skunk2 shift knob
Old 04-08-2002, 07:13 PM
Self's Avatar
What does your friend's GST have in the way of mods?
Old 04-08-2002, 10:11 PM
Off the top of my head...
14b turbo upgrade
Manual boost controller
Fuel pump (not sure what kind)
2.5" exhaust (soon to be 3")
lowering springs
performance downpipe
Apex AFC
Boost and AFR gauges
probably some more stuff but that's all i can think of, good for mid thirteens on street tires boosting around 18psi.
1991 CRX SI (black)
'90 B18A1 swap
Custom exhaust
*2.25" piping
'95 GSR 15" wheels
Powerslot rotors
Metal Master pads
Skunk2 shift knob
Old 04-15-2002, 03:41 AM
THE4TH's Avatar
THE4TH THE4TH is offline
Send a message via AIM to THE4TH
yeah nice run on the 3kgt.....
my buddy has one and i run him all the time
loses to a 95 gsr and a 00 si everytime rollin or not...
they are just heavy as all hell
S2000
1995 3000GT Turbo manual transmission problem rene8603 3000GT/Stealth 8 10-08-2009 03:49 PM
Any1 Trading 3000GT? Auto Or Stick please look WANTED3k 3000GT/Stealth 0 07-30-2009 11:46 PM
Check out my new 3000gt/Stealth Site! inflam52 3000GT/Stealth 7 07-15-2009 03:41 PM
For Sale 1999 3000gt $6,800 Jawz_3kgt Cars/Parts for Sale/Exchange 1 06-30-2009 07:43 AM
For Sale 1999 3000gt $6,800 Jawz_3kgt Cars/Parts for Sale/Exchange 0 06-29-2009 10:25 PM
