Old 04-28-2005, 08:42 AM
dugie6551's Avatar
dugie6551 dugie6551 is offline
Check for broken timing chain
I have a 1984, 2.8L carburated motor and it will not start.
It was running fine, then one day I went to back it into my garage and got it half way then it stopped completely. It will crank and I have drained 2 batteries trying to get it to start. It is getting fuel (replaced all lines, filters and fuel pump), it has spark (replaced plugs, wires, cap and rotor).
So now I am thinking the timing chain may be broken. Is there a "quick" way to check without tearing down the front of the motor?
Originally Posted by lamehonda
AF has ruined my life. .... Thanks AF
Old 04-28-2005, 10:15 AM
OverBoardProject OverBoardProject is offline
Banned
Re: Check for broken timing chain
You might have a little bit of oil hit the driveway, but pop the passenger side valve cover off and get someone to crank it over for a moment while you watch the valve train.
You can also just turn the motor over by hand just using the accessory belt. If it turns over easily then you have no timing chain left
Old 04-28-2005, 10:35 AM
hunter01 hunter01 is offline
Take the distributer cap off and have someone turn the engine over. Watch the rotor. If the timing chain is broken the rotor won't turn.
Old 04-28-2005, 10:46 AM
dugie6551's Avatar
Re: Re: Check for broken timing chain
Originally Posted by OverBoardProject
You might have a little bit of oil hit the driveway ....
It may be a little difficult to notice a "small" oil leak because the rear main seal is leaking and there is oil pretty much everywhere !!!
Thanks for the advice .. I will try both ways this weekend. If it is the timing chain, I would rather repair it then pay a mechanic to fix it !!! Of course the timing will probably be "off" but it's going in soon anyway, I'll let him do the timing. It will cost less cause I will do most of the labour !!!
Old 04-28-2005, 10:59 AM
blazee's Avatar
blazee blazee is offline
Problem?
If you are getting spark at the plug wires the timing chain ain't broke.
