Old 04-28-2005, 07:35 AM
builder77's Avatar
builder77 builder77 is offline
Compression Hose Fitting set
Can anyone give advise maybe a diary on how to apply Compression Hose Fitting set without messing up the braided hose?
I keep pulling the hose apart when I try to connect the fitting.
What glue do you use too?
Thanks for any help you can give!
Chris
Old 04-28-2005, 10:46 AM
SoCalMark's Avatar
SoCalMark SoCalMark is offline
Re: Compression Hose Fitting set
I put a small dab of CA glue on the end of the braided line and after it dry's I cut the end on an angle. The glue keeps the line together when you put the fittings on. I put all the fittings on the line, then cut the lengths you need with a pair of fittings in the middle of the cut line. I then put a small dab of 5 min. epoxy on the ends and slide the fittings to each end.
Mark
I like things that melt.
I dis-like things that don't melt.
